Question about Ardisam 5.5 Hp Rear Tine Rototiller
Tiller 5hp craftsman carburetor rebuild - Ardisam 5.5 Hp Rear Tine Rototiller
Part no .492611 carburetor assembly (inc.key
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=130202-3129-01&dn=8994004A
Unless you broke it or lost something, rebuilding it is more better on the pocket book. Rebuilding mainly consist of long carb cleaner soak, clean air
flow tubes with piano wire and air pressure. This most times can be done without any new parts. Fix IT!
Dec 22, 2011 | Craftsman Garden
I have a 5hp craftsman chipper model 247.795850, I am not ab;le to keep it running; it will start with starter fluid but when fluid burns off chipper stops. I put a new plug and air filters as well as...
Your problem is the carburetor, it needs cleaned (at a minimum), but you may have to give it a rebuild. Make sure that you clean all the littlee holes and passages.
Jun 02, 2011 | Craftsman Heavy Machinery
Is there a rebuild manual for the carburator
the little Walbro carburetors or those like it are difficult to rebuild successfully but as to your question, you should repace the parts as you encounter them in the carburetor.
Jun 02, 2010 | Mantis 2-Cycle Tiller
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
May 29, 2010 | Craftsman Garden
Briggs engine identity problem on craftsman tiller
sears.com
enter your mod#143.707012
May 26, 2009 | Garden
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
Unable to get the tiller to start, has new spark plug, diaphram. only fires once fuel is poured into carb. has a 5hp brigss and stratton
take fuel line off carburetor and see if you are getting fuel through the line.Is the fuel fresh?
Mar 23, 2009 | Garden
Ardisam 5.5 Hp Rear Tine Rototiller Logo
22 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
Shehu Pro
Shehu Pro
Larry Maranto
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
