Question about Toshiba SD7300 DVD Player
How do I get the correctly connect from the DVD player to the TV set?
  • Toshiba Master
  • 5,128 Answers
It depends on your TV's available inputs. If your TV has an HDMI port, you'll get the audio and HD video to your set with one cable if you invest in an HDMI cable; purchase the cable online (you don't need to pay $$$$ for the cable). Stores that specialize in cables will have the best picture. Press the HDMI select button on your remote to go through the resolution options for the DVD player. (see page 14 of the manual
If your TV doesn't have an HDMI port, check for component video. This will also give an HD picture to the TV. You'll need cables for the 2 RCA audio and 3 RCA (Red, blue, green) video plugs (or one cable with 5 RCA plugs) on each end of the cable. The mega-cables though can be a bit more difficult to plug in. Make sure that the colors match. (Some TVs use an adapter that consolidate the cable connection at the TV. You still need to match the colors at the adapter.)
If your TV only has composite in, you'll have an SD signal at the TV. This is the cable with one RCA plug (yellow) for video and the 2 RCA plugs (red and white) for audio. This cable is often included with the DVD player.
If your TV only has a coax connection (OTA tuner or analog cable), you'll need a Composite to RF converter. These used to be available at Radio Shack and can still be found online as well.
If some countries, the TV might have a SCART port. You can find a composite to SCART adapter.
The manual is available from Toshiba here: http://support.toshiba.com/support/modelHome?freeText=2805086 . Select the Manuals and Specs tab. The file is a PDF; so you will need Adobe Reader or a similar program to read the file.
I hope this helps. If you need additional assistance, please add a comment with details of your TV.
(if your TV has an SD (480i) resolution, you probably only have the composite and coax inputs.)
Posted on May 08, 2013
Correct placing of leads from dvd player into back of TV?
If you are using RCA jacks to connect from the DVD player to the Television (RCA jacks are the connectors that have a white & red colored end for right and left speaker sound and another yellow end for video) connect one end to the back of the DVD player where it says "out going connections" and the other end to the television in the "incoming" connections. Remove your television antenna from the tv to the DVD player. The antenna signal goes to the DVD player and the Dvd player sends the picture outgoing to your tv set.
I hope this helps?
Sep 12, 2011 | Panasonic Televison & Video
I just bought a sony dvd player model # DVD-SR200P and it has power and it counts on the dvd player but it wont show on any of my TV's?????????
check the connection from dvd to tv. check if you select the correct input settings on you tv... if the connection is ok and the problem is not solve, just bring it back to the store... ty
Jun 23, 2011 | Sony DVP-SR200P DVD Player
New DVR67)KU toshiba DVD video recorder/VCr recorder Problem: Cannot get on-screen display to set up new DVD machine. Both DVD and TV are Toshiba
unplug everything lets start over.....the TV is set on Ch 3..........and is working.... the new DVD machine should have red, white and yellow RCA cable.... connect these to the correct DVD outlets ........now connect it to the TV (digital IN)..... this is to view........ now to record using the F connecting cable plug this into the DVD (rear top right hand corner) this should be coming from your sat/cable out ........... now from the DVD F connector out .this goes to the TV...........note to record from another DVD player use the front jacks.........turn the power on and enjoy that movie(s)
Jan 27, 2011 | Toshiba Televison & Video
How do i connect a dvd player to the tv?
Behind DVD player you will have sockets
(red -Audio
white -Audio
yellow- video)
Same set of sockets will be there behind your TV also.
Please connect the Audio video cable correctly accordingly to the colour.
Now your DVD player is coonected to the TV. You can start using your DVD player
Thanx
Jul 23, 2010 | Disney Lightning McQueen TV
Problen in installation....
You have to make sure that the video output from the DVD player is connected to a video output unit which could be your TV, or if your computer has video inputs you might connect your DVD player to it. Then you have to set your TV or computer to the correct display. For example if your DVD player is connected to the VIDEO 1 input of your TV, you would use your TV remote to set your TV to VIDEO 1.
Jul 07, 2009 | Philips DVDR520H DVD Player/HDD
OTA HDTV ONLY
just do these connect AV output from your dvd player to AV input in your TV.
Jun 09, 2009 | RCA 27F650T 27" TV
Disk won't load
I would verify that connections between the DVD player and the TV; then go into your DVD’s control panel and re-set to original factory settings. I would also make sure that your TV’s settings are set to the correct connection settings as well.
It would also be nice if you included the make, and model of the DVD player and which connections are you using to connect to the TV.
Nov 10, 2007 | Televison & Video
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
Toshiba SD7300 DVD Player Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
