Question about Hotpoint Kitchen Ranges
Which fuses for Hotpoint Range Diamond Series?
I have an older Hotpoint Kitchen Range model KE747PW1. Some of the screw-in fuses on the top were busted and I took them out to inspect which ones were problematic. Unfortunately I lost count of the order and now have a mix of 20 and 30 amp fuses and don't know which ones go where. Any one can help?
  • Alexandre Huot May 08, 2013
    Thanks! Just needed to figure out which spot was the oven element by trial and error and it's all working fine now!
    Sergeant:
  • 330 Answers
The higher Amp fuses are for the oven elements and the lower amp fuses are for the burners on top and the lighting if applicable. Some models have it printed on a piece of paper next to the fuses holders. Let me know if it helps!
Posted on May 08, 2013
watugot
  • 290 Answers
SOURCE: my range electrodes keep firing
If you cleaned it with soap and water or a household cleaning solution, some of it has probably gotten down to one of the switches that control the surface ignitors. Very common problem. Leave it unplugged when you are not using it and they will dry out and return to normal. You can pull the knobs off and try using a hair dryer, it may help a little, but it basicly is just a matter of time.
There are different variations of this model. If you will post the complete model number I can probably tell you how to remove the top, but there usually is little reason to take it off unless something needs repairing.
Thanks/Mike
Posted on Dec 24, 2007
SOURCE: Dynasty DGRSC 30 Gas Kitchen Range parts replacement
Have you tried contacting Jade Products who manufactures Dynasty ranges? 866-607-5694
Posted on Dec 28, 2007
SOURCE: Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Posted on Oct 08, 2009
mreid542
  • 166 Answers
SOURCE: GE Spectra JBP78 Electric Kitchen Range
This should be a smooth top range. Smooth tops don't lift for cleaning - only for servicing.
Posted on May 29, 2010
TheMobilian
  • 8220 Answers
SOURCE: Can any one help me
See page 10
Posted on Jun 16, 2011
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Need help opening an older Caloric Prestige Series Range top
Generally you just need to place a flat blade screw driver in the crack about 3 inched below stove top and pry up, this exposes the entire under pan of the stove top.
Apr 07, 2014 | Stoves Kitchen Ranges
I took the oven door off and can't get it back on. I don't know the model or year but it is an older model Hotpoint. There are 2 (two) metal parts on each side. The top parts are longer with a...
If I understood your question correctly you are trying to replace the Hotpoint Oven door and cannot understand how to do it. Since you cannot specify the model I am posting a video link which will show you how to remove and replace the hotpoint oven door for a model older like yours.
http://www.youtube.com/watch?v=hSzc4Uqbbr8
Thank You for contacting Fixya.com
Aug 03, 2011 | Hotpoint RB757 Electric Kitchen Range
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
Where is the pilot in my hotpoint oven?
As far as I know, there is no pilot light in any domestic oven up to 25 years old and probably even in the older models.
Nov 26, 2009 | Hotpoint RGB745 Gas Kitchen Range
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Where is the fuse located in hotpoint rgb740 range?
This range does not have a fuse in it according to ge's lookup (Ge owns Hotpoint)
Apr 07, 2009 | GE Hotpoint RGB740BEH Kitchen Range
HotPoint Electric Stove
check your breakers check your cord make sure you have 220 volts at service block
Dec 06, 2007 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
150 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
