Question about Refrigerators
Window unit will not power on at all and throws the gfi on the power cord however a lamp pluged in the same out let works fine and the window unit works fine pluged in out in the shed and at the shop I took it to. Both outlets on either side of the window do the same thing freezer plug in to the other outlet works fine, could it be something to do with a loose ground wire on the electrical outlet. I will be able to take a look at it in a couple days and would like some ideas as what to look for and what to test and how.
    Sergeant:
  • 315 Answers
If the window unit you are talking about is an air conditionner(sorry, it does not say it in the text), you must remember that an air conditionner needs far more amperage than a light or a freezer or both. Have you tried to plug the window unit alone directly into an outlet and not in a power cord? Let me know if these suggestions helped! Good luck.
Posted on May 08, 2013
2 Suggested Answers
  • 1462 Answers
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Posted on Jun 19, 2007
Koldfront 12,000 BTU Heat/Cool Window Air Conditioner - WAC12001W power keeps tripping cord gfi
That is a big unit. Is the outlet itself supplying sufficient amps?
Sep 04, 2016 | Heating & Cooling
When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Apr 03, 2015 | Heating & Cooling
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
We have a LGHD25000ER window unit. It's on a 220 line. It was working fine until last night. When you plug it in the G.F.I. on it's line from the air conditioner it pops instantley. We have already...
There has to be a shorted wire in the Air Conditioner then....the GFI is suposed to do that if it senses a short anywhere in the circuit and if it is happening when the air is plugged in then it must be in there....
heatman101
Aug 20, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Mar 27, 2010 | LG Electronic Window Air Conditioner
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
GE XL44 Broiler/Self Clean Trips GFI
This should be a 220 volt appliance so I'm trying to figure how this was connected to a GFI. Does it have a second connection to power the controls?
Most GFI uints I have seen are not rated for large amounts of power consumption. I used to throw the one in my bathroom if I was running the electric heater and the wife fired up the hair dryer.
I'm wondering if this indeed does require the additional 110 connection then it sould be pulling heavy current from it to aid in the cleaning process. I've never seen a stove that needed the extra. My old electric range had only the 220 as well as my elders.
So if that is the case then you should not be running that through the GFI outlet because of the heavy drain will heat the breaker in the GFI and cause it to trip. Breakers actually work very similar to how the old fuses work. Heat causes the switch to throw. GFI units have a lower tolerance (designed to detect shorts quicker to save your life) and trip quicker than breakers do.
Apr 02, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
