Question about Refrigerators
Norcold 3163 Fridge
The fridge works 100% on LG, I've not tried DC but AC should be working, was last year, but this year it seems no power is going to the unit - they outlet it's plugged into has power. Is there a reset/overload button or a fuse between the switch and the unit?
  • Mike Emm Jun 18, 2013
    Hey JT - I've been busy with work, just getting back to this fridge now. I pulled it out, and using an AC "Tick Tester " I can see that power is at the T-Stat, but there is no power coming out of the T-Stat. Interestingly, the T-Stat does work when running propane. Is it possible to change out the AC side? It looks like one large unit so maybe the AC side is malfunctioning? Previous owner said it worked fine, any troubleshooting hints?
  • Refrigerators Master
  • 4,655 Answers
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
Posted on May 10, 2013
  • 10 more comments
  • John Tripp
    John Tripp May 10, 2013
    Here is a link that may help you find the fuse. The fuse can be seen mounted to the top of you refrigerator... http://1705.net/archives/329
  • Mike Emm May 14, 2013
    Thanks, unfortunately, I've already popped the fridge out to find that fuse was not blown and that power was moving through the fuse. Any other thoughts?
  • John Tripp
    John Tripp May 14, 2013
    Try this link below. Sorry I thought the link above was good but Fixya has changed how we are able to attach links. You are going to need to check the electric heater next to see if it has continuity.
  • John Tripp
    http://appliance911seabreeze.com/Norcold...
  • Mike Emm May 22, 2013
    using a tick tester I can tell there is power on both sides of the fuse, but don't have a volt meter on location, any other way to test continuity?
  • John Tripp
    John Tripp May 22, 2013
    You can pull the fuse and have someone test it. You need to find a meter so you can test the heater element. Or pull the element out and see if someone can test it for you. Thanks JT
  • John Tripp
    John Tripp May 24, 2013
    Is the control panel lighting up at all? Most of the controls on these units us 12 volts DC and if you are at a location where there is no 120 volts AC If you are not getting DC voltage or if the board is bad the refrigerator will not work at all....JT
    Hi JT - been busy with work. Pulled fridge, used AC "tick tester" and there is no power outbound from the T-Stat? The T-Stat works on propane, last owner said AC worked perfect, any troubleshooting hints for the T-Stat? Possible to replace just the AC side of the unit?
  • John Tripp
    John Tripp Jun 20, 2013
    If the thermostat is where the power ends while on AC power I would suspect the thermostat is the problem. The AC circuit is simple on your model and has the drawing on page 10 of the service manual. Sure you can change it out but I would focus on finding the problem and solving that....Thanks JT
  • Mike Emm Jul 12, 2013
    Had a chance to get back to it. I pulled the input AC off the T-stat unit, and the outbound to heater off the T-Stat and jumped them together. I can toggle power on/off, and when left on (100%) the heater functions. So, it seems like it's a T-Stat issue. Any idea where I can get one cheap, used or any other tips to repair it? It's odd b/c it does work when the fridge is running off LG.
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Norcold DE0061 fridge
make sure the 12 volt side fuse is not blown
Nov 29, 2013 | Thetford Norcold® Model DE0061
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
Norcold Model 6182 Operates on lp ok Replaced ac
click this link http://bryantrv.com/docs2/docs/600.pdf this is the repair guid to your norcold includes the 6100 models on page 25 starts the Dc operation testing as well as a Dc Trouble shooting guide I would suggest you go through this troubleshooting section as it will help you greatly to diagnose what the issue is with your unit. After you complete the tests mentioned if you have any further questions message me back I await your reply Thanks again Rick
Jul 24, 2011 | Refrigerators
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
No power to refrigerator unless it is hooked up direct. Think it is 12 volt dc supply connection. Could this be the problem only able to get partial # on part c1c 5122 is all we can read.
there is an inverter built in to the power supply that converts dc to ac to run the compressor if the fuse is ok. you will have to replace the supply . or for traveling you could hook up a small inverter to opperate the fridge while traveling this could be connected to the 12 vlt line for fridge power as it will not take much more power than the the fridge needs.
Feb 21, 2011 | Thetford Norcold® Model DE0061
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
