Question about Kenmore 15.5 in. Pedestal
Can the pedestal(15")on my washer be removed and how
Model# 11045091404
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Can you remove the front panel on an HE washer
Hey gearman, In a word, Yes. I find it easier to extend the drawer out ( if applicable...some pedestal's don't have drawer's ) and then the panel will drop down un-obstructed once the screws are removed. Hope this was helpful and answered your question. Please take a second to rate this solution if to your satisfactory, if not let me know how I can assist you further. Thanks for visiting "fixya" and good luck. Macmarkus :)
Posted on Apr 01, 2010
richroth
  • 9472 Answers
SOURCE: wash cycle light keeps on blinking washer model 11045091404
Remove the bottom kick plate and clear the filter. Post back the results.
Posted on Nov 20, 2012
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Jan 13, 2016 | LG WM2487H Front Load Washer
Wash cycle light keeps on blinking washer model 11045091404
Nov 20, 2012 | Kenmore Elite 45986 Front Load Washer
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
I need to know if it will fit area of 52" high
You will need at least 53 inches. 14 3/8 for the pedestal, and 38 5/8 for the washer/dryer.
Oct 27, 2010 | Samsung WE357A7U 15" Pedestal for Washers...
How can I place my dryer/washer In a higher plcae?
I strongly recommend on 15" pedestal for washers or dryers by Samsung (model WE357A7P).The 15" pedestal will allow you to lift your washer or dryer to a more convenient height and will allow more storage with its convenient self closing drawer.
Aug 15, 2010 | Rival Kitchen Appliances - Others
Aug 12, 2010 | Amana Washing Machines
I strongly recommend on 15" pedestal for washers or dryers by Sam sung (model WE357A7P).The 15" pedestal will allow you to lift your washer or dryer to a more convenient height and will allow more storage with its convenient self closing drawer.
Aug 12, 2010 | Washing Machines
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
HOW DOES THE DRAWER TO MY PEDESTAL BASE MODEL SBSD137H5WW , SERIAL NO. HR124045G COME OUT SO I CAN SECURE THE SCREWS AT THE BACK INTO THE WASHER AT THE TIME OF INSTALLATION? MY WASHER IS A GE MODEL...
Went back to Lowes to talk to a sales personal. He informed me that there are two screws at the front of the drawer (one per side) After removing these screws (you will need to put them back after) the drawer will be removable from the pedestal base.
Nov 13, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
