Question about RCA RT2280 System
RT 2280 System Speaker Problems - RCA RT2280 System
Only right side tweeter working
check you haven't got the wires on the back of the tweeter touching, Then check the rest of the wiring you may have touched. Jon
Dec 18, 2014 | Cars & Trucks
Sound (Audio) Drops Out
This unit is shutting down the outputs probably due to heat. There are thermal detection transistors inside that will shut off the output amp section if it gets too hot. There can be a number of reasons for this. Check the speaker wires to be sure that they are not frayed at all and that none of the strands are touching. Other than that there may be defective parts inside that are sensitive to heat.
Dan
Jul 15, 2008 | RCA RT2280 System
No sound comes out of my Cobra29 xlassic
speaker turned off
rt clk speaker icon in system tray then playback devices
enable speaker
if not headphone socket may be bad.
Dec 10, 2013 | Computers & Internet
Radio problems
try speaker on other side as test part if still not working trace wire for breaks if ok rt channel in audio unit out and needs replaced.
Aug 01, 2012 | 2003 GMC Sierra 2500HD
I Have am RCA RT2280 that has no power accept for the led on the power button, Any Ideas?
My RCA 2280 receiver went out on me one day. I thought I'd have to take it to the shop. But before I do that I'll check the fuse because I took it to the shop once before and the repair man said that it was the fuse, he replace it with a new one. So I thought that I would take a look inside first. I took the cover off and looked around and notice that the fuse looked loose. It was loose. I just push it all the way in, replace the cover, plugged it back up and it worked.
As far as the on and off problem goes (which happened to me too) the speaker wire coming from one of the speakers to the back of the receiver were crossed, over loading the system causing it to over heat resulting in it shutting off. I found that the wire was going from red to the gray instead of red to red and gray to gray. Once I rearranged the speaker wires I had no more problems and that was years ago. I haven't had anymore trouble sense. I've had the receiver maybe 12 years now.
Except for today with the Dish Network 20.0 IR 155681 remote control for the 722k HD/DVR. I tried everything in their book but I can't get it to control the RCA 2280 surround sound volume. Anybody gotta clue? I would surely appreciate it. Good Luck.
Dec 14, 2011 | RCA RT2280 System
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Gateway- built-in laptop Speakers not working
Heat dissipation from the unit in the same area of the speaker assembly, especially since you stated that the RIGHT speaker was smoked. Similar problems occur with this design flaw with any manufacturer as HP has the same problem with some of their models.
Your heat exhaust is killing the speaker, and I would also bet that your chipset is AMD and not Intel, the latter having solved it's heat dissipationn problems.
A more aggressive heat dissipation solution on the motherboard or redirection of the exhaust past fewer heat sensitive components would be a design goal.
Mar 29, 2009 | Gateway MX6453 Notebook
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
RCA RT2280 System Logo
57 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
