Question about Saniflo 030 Extension Pipe for Installing Sanibest & Saniplus Behind Wall
Discharge elbow leaking macerator
Hi I have a Sanitop Broy Pro macerator. The macerator appears to be pumping correctly, but it is leaking from the discharge pipe. I have tightened the jubilee clip that attaches it to the top of the unit, but water keeps leaking from the side of the rubber seal. Does anyone know what might be causing this?
  • 171 Answers
SOURCE: toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 145 Answers
SOURCE: Saniflo Sanitop pump keeps running
CHECK YOUR OWNER BOOK
Posted on Dec 12, 2008
  • 659 Answers
SOURCE: Very Noisy Sanitop Macerator
http://owneriq.net/
You will probably be able to find a user manual on the above link. It will tell you whether or not there has to be maintenance on this toilet. I doubt it but it is possible. There should also be trouble shooting advice as well. When all else fails, contact the manufacturer. They will be able to tell you what the problem is and guide you in the right direction.
Posted on Mar 21, 2009
  • 33 Answers
SOURCE: macerator discharging water out of outlet pipe
sounds like a switch problem again. try descaling the unit. otherwise its time for a new pressure switch.
Posted on May 10, 2010
  • 33 Answers
SOURCE: Hi i have a saniplus macerator unit hums but
sounds like an obstructed unit - you would need to remove the impeller cover at the base to check the pump - i'm assuming youve already checked the blade unit at the top (be careful here - i use a screwdriver - not my finger) could be that a simple cleanup and acid descale would be all thats needed. try this first then start looking deeper.Humming indicates motor is ok - but dont let it run continuosly - you dont want to burn out a good motor.
My saniplus leaks/sprays watse from the discharge elbow at the base of the unit, it is popping up and leaking during discharge
no,you need to take it apart and replace the gaskets,they are under pressure and glue will never hold,read about it here, Saniflo Extension Pipe
Sep 16, 2014 | Saniflo SaniPack SaniPack Concealed...
LEAK AND SMELL
question aint clear.what do you want? this is in relation to plumbing and drainage however try to use ordinary instruments like gauze wire to filter the water so as to stop the blacking and you can use a rubber to hold the outlet pipe that pushes into the top of the macerator box.try it
Nov 20, 2012 | Saniflo & Saniplus& Macerator Pump
Water keeps flowing back into the macerator
There should be a check valve installed in the discharge elbow, check if the check valve is installed or it might just be stuck open so when waste water is pumped out, it slowly drains back into the unit creating water pressure that is making it kick on and off.
Oct 07, 2012 | Saniflo & Saniplus& Macerator Pump
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Need to fit a toilet to an upstairs room with only a 2 inch pipe for evacuations of water and waste ,a hand basin also
The perfect solution will be to use a Sanitop, Sanicompact 48 or the Sanistar model. Visit the Saniflo website at www.saniflo.com for more detailed information.
Nov 04, 2010 | Saniflo & Saniplus& Macerator Pump
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo keeps going off when not flushed
Water pressure makes the unit turn on and off. If it turning on by itself then could be water draining back into the pump. Water could be leaking from the check valve on the discharge elbow into the pump or from the toilet tank into the bowl. Inspect the flapper on the check valve and the flapper on the flush valve.
Aug 09, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
How do I know if the macerator is working if I flush the toilet I acn hear the pump start and see the 22mm outlet pipe vibrating as water is pumped thru it. But I'm not sure if macerator is working. Does...
If you flush the toilet at least 3 times and water does not back up on the toilet then is working. In case the pump fails the pump will fill up about 3 to 4 gallons of water before it overflows or backs up. You can also try disconnecting the discharge pipe off the discharge elbow and place a bucket at the end of the discharge elbow and flush the toilet into the bucket, if water is discharged into the bucket then is working properly.
Jul 20, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo 030 Extension Pipe for Installing Sanibest & Saniplus Behind Wall Logo
37 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
