Question about Baumatic B187 Stainless Steel Electric Single Oven
Baumatic single oven green light
Are mains tripped in my house and all electric turned off! Since then the coven will not work and will go the temperature you put the thermostat!
SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Posted on Dec 31, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Posted on Jan 01, 2010
ginko
  • 19396 Answers
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Posted on Mar 03, 2010
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Aug 04, 2010 | Baumatic B187 Stainless Steel Electric...
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
Why is error code F8E0 appearing on my Baumatic B205SS oven and alarm sounding
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
Mar 03, 2010 | Baumatic B205SS Stainless Steel Electric...
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Oct 11, 2009 | Baumatic B187 Stainless Steel Electric...
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Baumatic B187 Stainless Steel Electric Single Oven Logo
16 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
