Question about Jet Tech Systems STEALTH Dishwasher
What is causing the problem
Top or bottom spinner neither one turn
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 | Dishwashers
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Middle and top spinners do not spin The pump is pushing water up the back delivery tube. There are no dishes in the unit and I was able to trick the door into thinking it was closed so I could watch what...
Remove each spray arm and check it is clear of food particlesat the jets. The next problem may occour at the rotating joint . If the seal is not good, you can loose a lot of water out of this point.. If both of these seem reasonable, then yes the circulation pump may need checking. First check for any debris in the impeller, and that it is not worn or damaged, and that it is attached to the motor or the coupling is still good. If these are ok, then the motors='s capacitor may be faulty - causing it to buzz more than normal usually, and it looses efficiency, getting hot in the process.
One of these should solve the problem !
Aug 05, 2009 | Dishwashers
Bosch dishwasher shu3032uc-14 doesn't clean very well tried different things but no help sometimes i can catch top spinner not working all the holes are clean where is the water level supposed to be and...
Pour a gallon of white vinegar in bottom run halfway thru wash cycle turn off let unit sit overnight to properly soak-then run a couple of times to rinse out vinegar(vinegar dissolves calcium which causes unit to not function properly) also check unit inlet for contaminates and clean as neccesary install inline filter if not one there..(the hot water tank will tell if you have a calcium problem(hard water problem)shut off unit undo relief valve on tank hook up hose to bottom then drain check for white chunks),calcium wreaks havoc on all household appliances and shortens there lifespan!!! :)
Jul 05, 2009 | Dishwashers
The water spinners inside are not turning on top
These are the spray arms. If both are not operating - are you geting any water through them at all?
If no - then the fault is the circulating pump or control circuit. Not cheap I'm afraid.
Spray arms are usually ok.
If you are getting water throuh them, then remove them (2 clips or a large nut), and rinse them through. Oftem bits of food get past the filter, and end up blocking all the holes. Make sure they are all clear.
Jun 28, 2009 | Dishwashers
Removal of spinner (it turns the spray arm) on top of pump housing.
If your talking about removing the bottom, main spray arm for the MDB7100AWB, in the middle there's the little hole with a plastic cog, button, whatever you want to call it that you can grab in pull up and spin, but this is just a spray jet and has nothing to do with removing the arm. But, around that hole in the middle is a disc that is somewhat flat and only sticks up about an 1/8 of an inch from the arm, this is what you need to unscrew to remove the arm. It almost looks like part of the arm (especially if it's caked with detergent), but it's actually the screw fastener that holds the arm on.  Just muscle that disc, turning counterclockwise, and it should unscrew, then you can remove the main arm unit.
For the top arm, it just pulls straight down and pops out.  You feel like it's about to break, but then it just pops out.  To put it back in, it just snaps in when you push it in.
Hope this helps.
May 26, 2008 | Maytag MDB7100AWB Dishwasher
GE Washing Machine
I dont kow what you mean about a spinner? If your talking about the part in the middle thats caled a agitator. If your washer is the model with the plastic tub the agitator pulls up from the bottom. And I have to tell you it is not a easy thing to pull out. The hard gritty substance could be from your water. You might want to have your water checked. Hope this helps you.
Jul 13, 2007 | GE WDSR2080D Top Load Washer
Jet Tech Systems STEALTH Dishwasher Logo
16 people viewed this question
Top Jet Dishwashers Experts
Owen Barnes
Are you a Jet Dishwasher Expert? Answer questions, earn points and help others
