Question about Nokia 3220
3315 no power
3315 dead set unit
  • 35 Answers
Charge battery carefully if problem not solved , change battery. Thank you
Posted on Aug 11, 2007
SOURCE:
HOW DO YOU TURN OFF TWO-SIDED OUTPUT ON A XEROX 3315
1. If printing in the computer , select Printing Preferences in the computer choosing Xerox 3315 as the printer then choose single sided setting, Apply and OK. that should change the default setting for your computer.
Sep 08, 2017 | Xerox Office Equipment & Supplies
Security code nokia 3315
The default security code for a Nokia 3315 is "12345". If you have changed it and forgot it, You can do a master reset to your mobile phone. This could restore your phone with default factory settings. You can get the master reset code for your Nokia 3315 from www.Unlock-Free.com for free. Good luck mate.
Feb 13, 2013 | Nokia 3315 Cellular Phone
How to know the security code of your phone
Hi, The default security code for a Nokia 3315 is "12345". If you have changed it and forgot it, You can do a master reset to your mobile. This would restore your phone with default factory settings. You can get the free master reset code for a Nokia 3315 from www.unlocking4free.com by submitting your mobile model and IMEI number.
Aug 21, 2012 | Nokia 3315 Cellular Phone
3315 dead
Consider recycling it, most major electronic retailers now have a recycle program for dead electronics which at the most is a very minuscule fee. Also consider contacting your Cellular service provider or Nokia for responsible recycling options.
Mar 01, 2011 | Nokia 3315 Cellular Phone
Nokia 3315 network problam
hi
these problem are frequent in this phone.just contact your customer care of your mobile..
they ill change your settings of your mobile or they will change the hardware of your mobile
thank you
Dec 17, 2010 | Nokia 3315 Cellular Phone
3315 Cellular Phone: My mobile model is nokia 3315 ringer is fine b...
the phone has 2 speakers!
1 speaker to voice calls
1 speaker for the ring tones
one off them is damaged
May 06, 2010 | Nokia 3315 Cellular Phone
How to upgrade my 3310 to 3315
If you only wanted to Know procedure, this is exactly how you need to go about it :-
To upgrade 3310 to 3315 you need to reflash your phone to new version. Seems to be first version used both in 3310 and 3315 (Asian version of 3310). After 5.45 firmware for both is the same. From this also changed PPM packs (for example, Polish is now saved in "N", not in "J").
First of all you must remove SimCard from phone and charge battery.
Below you will find full step by step solution:
1. By using Universal Box v3.0 make a backup of flash from your phone with range 200000 - 400000 (it will be safe backup if somethign will goes wrong). If you don't have Universal Box v3.0 you can use standalone Dejan Flasher and Mbus cable.
2. With Universal Box v3.0 or Dejan Flasher upload software 3315 (v5.45) that can be downloaded from our Free flashes-> Nokia page - please take oportunity to vote for us. Start address is 200000
3. After flashign operation ended run software KNOK that can be downlaoded from our page "Free Download-> Nokia". Connect phone to function RJ in Universal Box or if you don't have Box use Mbus cable. In Mbus function choose - Phone Settings -> Quick set FAID
4. Then choose Phone Settings -> Set new imei - and enter IMEI of phone. You can read it on back of phone.
5. Then choose Modify Lock -> Reset SP lock. After ended this choose once again "Phone Settings -> Quick set FAID "
6. All is completed. If phone require security code please enter 12345.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Nokia 3310 Cellular Phone
Hi sir my problem to my phone model 2600 is no power pls...................help me sir
If there's no power, then the battery might be dead. Check the connections are totally clean. You may need to have to order a replacement battery.
Apr 12, 2009 | Nokia 3315 Cellular Phone
Our nokia 3315 mobile is not charging ,what is the problem?
Check first your charger unit for cut or loose connection. If you can clean your unit's board this could help. But if the charger IC is shot you better bring it to a cellphone repair shop.
Apr 11, 2009 | Nokia 3315 Cellular Phone
Nokia 3220 Logo
93 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
