Question about Sole Fitness Sole E35 Elliptical
Rubber wheels squeak on the rear. - Sole Fitness Sole E35 Elliptical
Steering wheel squeaks on my 2006 raider.
remove fat knees. (joking, LOL)
squeaks inside car or outside?
inside, remove plastic shields, from column
still squeak. ?
Oct 16, 2013 | 2006 Mitsubishi Raider
Rear mounted wheel on my touareg squeaks when
The wheel or tire doesn't squeek
The suspension,brakes or exhaust may
If you talking a wheel mounted on the back
not on the axles surely you can figure that out
Aug 12, 2013 | Volkswagen Touareg Cars & Trucks
I have a squeaking noise coming from the rear of my 06 range rover hse what could it be
Rear suspension bushings will squeak, Dealers will want to replace them all, Give them a good soaking with a rubber lubricant and they will stop making noise, I use Ruglyde, it is a rubber lubricant for mounting tires and works very well for this squeak
Dec 11, 2012 | Land Rover Range Rover Cars & Trucks
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
The car makes a squeaking noise when driving
Beyond the issues of dry wheel bearings and CV joints, various points in the suspension (front and rear) have rubber pivot points that get squeaky when moved. Try pushing down on each corner of the car to try to locate the area of the noise. Is it worse on rough roads or smooth? Make sure that all of the lug nuts on the wheels are tight. Lastly, doors, hood, and trunk lid can squeak if they move while driving. Silicon spray lubricant works on all rubber surfaces. Wheel bearing grease works on wheel bearings and CV joints--look for wear and replace any damaged part.
Oct 23, 2009 | 2005 Ford Focus
Clothes dryer has a loud squeak
The drum belt could be slipping. A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 16, 2009 | Dryers
Squeak from front left wheel...
It could probabely be the brake pads ,some cars have worning light come on and others have this little projection of steel piece working as warning tht the pads needs replacement.
Remove the front wheel andyou will be able to see the brake calipers and the pads.
Good luck.
May 10, 2009 | 1993 Honda Prelude
Sole Fitness Sole E35 Elliptical Logo
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
