Tevion sound 6304
Batery
How can I get a schematic for the Tevion 32" 32081d
I doubt there is one as it is a generic chassis made in spain/china for Tevion. Firstly check the supply to the main board processor, 5V and 3.3V should be present. If not, check the power supply.
Oct 05, 2016 | Computers & Internet
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
_____________________________________
Tevion DVD-200 Region Free Fix
on Apr 25, 2010 | Televison & Video
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
I can get sound on my Tevion DVD creator
This problem s a little rare actually...
but here's a quote from a particular site.
Full review by
manxix
on 4th Feb 2009
User Rating : 3
Respect : -1
The Tevion DVD Maker setup wasn't too bad even for a greybeard. Use wasn't too bad either. but... ... what instructions? pretty bad and leaving loads unexplained. I CAN'T GET SOUND TO RECORD NO MATTER WHAT. Tevion DVD Maker is small, should be perfect - if only I could get that sound. I found that an adaptor (scart to pin) was needed AND a lead male to male as the adaptor and the Tevion both had female leads. My model is VS-USB2800D
Dec 19, 2010 | Computers & Internet
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
I have a tevion mp4 player and have downloaded music on it using a software called iMeash. I wanted to dowload videos too but everytime I did my mp4 player wouldn't accept it. SO i tried researching and i...
Every file (that contains video or sound etc) has something called file extension like mp3,mp4, mtv and avi etc. This MP player "Tevion MP4 player"needs to be in in MTV file format. If you have purchased it you will get a CD with it. and this CD contains the converter to convert the MP4 file format to mtv so you can run it. If you do not have the CD than you can download it from here.
http://www.fascin8.co.uk/support/8198.exe
I recommend that you watch the following video related with this product
http://www.fascin8.co.uk/f8/tevion/mp4/4gb-mp4-4701
Be confident and do not be hesitant, If you still have problems with tevion. Change your media player to VLC. Plays all sorts of video and sound files even mp4 and flv and above all its free.
Good Luck!
Aug 09, 2010 | Computers & Internet
65 people viewed this question
 Grubhead
Grubhead
