Question about GE Spacemaker JVM1640SJ Microwave Oven
Brother put a foil wraped burger in micro now everything is dead
I am an a/c technition so i'm a verry good trouble shooter but I've never worked on a microwave.I have power coming to the micro and the fuse behind the display has continuity.But all displays are dead and nothig works.Can someone please tell me where to start troubleshooting.
  • markuskash Aug 11, 2007
    The Problem ended up being a high tempiture limit switch located near the light inside the unit.It looked to be a automatic reset but the diapham must have warped.I just wire nuted the wires together because the limit runs in line and called it a day.I know this is a little dangerous but I wanted my micro working.Thanks for your help.
    Brigadier General:
  • 6,966 Answers
Hi, You may want to try to check/troubleshoot the PCB underneath the display/control panel. The mains do supply two circuitries: the heavy load and the electronics. In some units, they have a standard transformer while in others an SMPS that supplies the +5 (and sometimes +12 or higher) voltage. This powers the electronics which includes a microcontroller, timer, relay drivers and display panel. Trace the transformer/SMPS and look for any fusible link, secondary fuse or surface mounted fuse. More often than not, there are also standard components along the way like bride diode, diode, filter capacitor and regulator IC. Check for VDC input and output of power components. Hope this gives you an idea, Pls post again how things turn up or if you need further information. Good luck and kind regards.
Posted on Aug 11, 2007
6ya staff
SOURCE:
My GE Profile Spacemaker XL(JVM1350BW 002) starts a loud buzzing noise 3-5 seconds after started and is not heating food. Any thoughts or is it dead?
Hello Scott MacAskill,
I would say it is only dead if you want it to be...
BIG noise is USUALLY a bad transformer... Sadly your is about $200 USD... so EASTER egg trouble shooting could be COST PROHIBATIVE.
SERVICE manuals begin at $9.95...
Youtube is generally full of WILDER GUESSES than mine...
Try the on-line support from SEARS...
Just check your prices before buying anything from them...
(my opinion... after getting personal shafted by the 3 TIMES).
Parts are available...
(must be a nice unit.. pretty $$$$ parts)...
I have my own nemesis... a MARVEL 6RFI refrigerator...
My wife loved it for 20 years...
Then it needed serious servicing...
Every MARVEL part I try to buy is marked up $150 just for the name... I find the exact parts & have my Supco Fan for $22 instead of the $172 for a MARVEL fan...
GE is highly serviceable & popular...
If you are willing to put in the time... Newer appliances are just
not quite as good...
They are practically tin-foil (with no added features)...
Your choice... Sadly my wife only tolerates my FIXING ...
She would long ago put it on the trash heap
(ice maker, stainless steel & all)...
Alas (what have you got to lose by trying?)
http://www.appliancepartspros.com/search.aspx?model=jvm1350bw002
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
Apr 25, 2017 | GE Microwave Ovens
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
My microwave keypad doest not work apparently. It says "service may needed". How can solve this error.
HELLO.
The solution to your microwave problem is explained below.
Things You will Need
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Two buttons on keypad do not work
HELLO.
The solution is to work on your microwave keypad as explained below.
If there is need for further assist,notice me
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile JVM2070sk02 Every thing works and lights up but touch pad will not take any input. Fan ,Boost and light work .
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave will not take any input, you can follow these simple instructions to fix it.
needed things.
* Foil
* Tape
1. Unscrew the 2 screws in the top vent grill and remove it.
2. Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
3. Put a sheet of foil into the large ziplock bag and seal it up.
4. Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
5. Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
Will tin foil in the microwave ruin it completely? The microwave turned off after my son mircowaved a potato wrapped in tin foil.
You should always put a spoon in a cup of liquid that you heat in a microwave oven.
The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble.
1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight.
One might ask the question how old is your child and should they be using such a machine unsupervised!
Nov 05, 2009 | Microwave Ovens
There is a round silver disk (seemingly made out of card board) that fell off. Can it be replace with another cardboard cut out in the same shape?
the disk is just a microwave diffuser but, it is made with a special foil do not put regular foil into a microwave for any reason; just glue the disk back on with ordinary glue
May 20, 2009 | Microwave Ovens
Micro wave
A paint formulated for microwave ovens is available. Go to www.applianceaid.com/partsmicrowave.html and you can buy there, or do a Google search.
Jan 29, 2009 | Welbilt MR622W Microwave Oven
Microwave shuts off after a few seconds
Nov 22, 2007. I also had the 3 second shut off problem with my G/E 1650 MWO. Read all the above and tried them all. Finally I just took a 8" x 8" piece of Reynolds Wrap Aluminum foil and but it in an zip lock bag and placed it behind the control panel. It's been working for 2 weeks now. Just take out the 2 screws that hold the vent across the front right above the door. Next on the right side is one screw, take it out and then gently lift the control panel (panel with the buttons) about 1/2" and it will fold out and stay there. put the zip lock bag inside. Close it back up. I'd test it before replacing all the screws. You don't need to un-plug anything. Just don't stick your fingers on all the exposed parts...Mine works great now and didn't cost $0.10.
Oct 26, 2006 | GE JVM1653 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
