Question about Car Audio & Video
Serial number for car radio pontiac g6 gt - Car Audio & Video
emissionwiz
  • 80668 Answers
SOURCE: transmission fluid for 2007 pontiac G6 GT
This car does not have a auto trans dipstick, the level can only be checked by the dealer, this is a growing trend that started with most German cars, the filter is inside the trans pan and only needs changing every 60,000 miles.
Posted on Jan 06, 2009
Molson02536
  • 3854 Answers
SOURCE: where do i add transmission fluid to my pontiac g6
You can add transmission fluid to you transmission through the transmission fluid dipstick tube. Take your time and use the right size funnel, check and dubble check to make sure you don not over fill. Over filling the transmission is just as bad as not haveing enough fluid too.
Good luck and hope this helps
Posted on Apr 19, 2009
UpfrontAudio
  • 47 Answers
SOURCE: safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Posted on Apr 20, 2009
SOURCE: Pontiac G6 radio change problem
I had the same problem. You have to buy a bunch of extra parts and even then it probably still wont work. I ended up buying an aux input and hooking it up myself. It took 20 min and sounds great.
here's the link
http://www.crutchfield.com/S-3VMYH5qYDzF/p_142FMMOD02/Scosche-FM-MOD02.html?tp=1287&tab=re
Posted on Jun 30, 2009
  • 53 Answers
probably not but the switch over is ez you probably need a harness..thats about it..
Posted on Jul 10, 2009
My radio has no power at all,car is a 09 g6 gt
Check the fuse box for faulty fuses for the radio/accessories and the cigarette lighter. Replace the fuses with the correctly rated fuses.
Oct 27, 2012 | 2009 Pontiac G6 GT
Pontiac G6 radio
Jul 10, 2009 | 2008 Pontiac G6 Sedan
Pontiac G6, 2005. Power to Radio
Have you tried checking the SPEAKER WIRE?
Neil
Mar 14, 2009 | 2007 Pontiac G6 GT Convertible
Radio
I assume your audio system has anti theft.. You have to enter a code to restore operation of radio... But first check the fuse for the radio..If you dont know the code and are not original owner you will need to remove the radio and locate the model and serial number and then call the dealer to obtain code.... Be warned they might want to charge you ...Good Luck
Dec 27, 2008 | 2006 Pontiac G6
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
