Question about Microwave Ovens
Baumatic bt2530ss gas oven
Door won't close
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 20, 2011
ercupa190
  • 12223 Answers
SOURCE: Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Posted on Jul 15, 2012
Testimonial: "Was scared to try your fix but thanks."
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Power won't shut off when door closes
One or two micro switches are defective, "door switch"
Apr 02, 2012 | GE Profile Spacemaker Over-the-Range...
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
here.
Dec 04, 2011 | Whirlpool Microwave Ovens
My microwave not starting
My microwave on top of stove oven,whirlpool gold. When i closed the door but it keep said"door"and won't start.
Jul 21, 2011 | LG MS-0744Y Microwave Oven
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
