Sony RDR HXD710
Very dim front panel display
2 Suggested Answers
  • 124 Answers
SOURCE: Sony rdr-hxd710 dvd/hdd recorder stuck on welcome.
Set your Television to the corresponding input line. If you have the DVD recorder connected to your television input 1 line. Set your television to input 1 line. The recorder is just waiting for your command to set your time and area ...etc.
Posted on Nov 12, 2008
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
I have sony rdr vx 420 i am trying to transfer video to dvd on the machine and i cannot find the user manual, is this possible to do? i have tried pressing buttons that i thought would work but i cannot...
You may download the user guide for free support site Please find the link bellow.
Before you start, make sure to use the input button on the sony remote to select L1 or Line1 on the front panel display.
http://www.sony.co.uk/product/dvd-recorder/rdr-vx420#pageType=manual
I hope this helps :)
Mar 10, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Jun 22, 2009 | Sony RDR-VX515 DVD Recorder/VCR
My Sony CDX-C680...
Hello greggerika,
It's possible that the "illumination" wire is not connected or connected improperly. It's also possible that the front panel electrical connections are not making proper contact. Remove the front panel and gently clean the contacts with a pencil eraser.
Also, the CDX-C680 allows you to select either green or amber illumination. One or the other may be defective. Try changing it. Press SHIFT - press "3" (set up) three times - press "5" (right arrow) to change the setting. Also check the setting for "dimmer". ON will result in a dimmed display at all times. AUTO will dim the display whenever the headlights are turned on (if the wiring is connected properly). OFF will result in the brightest display at all times.
Hope this helps.
Jun 13, 2009 | Sony Car Audio & Video
I cant get my remote reverted back 2 factory settings because it wont work at all because its the player is set in dvd 3 and the remote is not ....so how do i reset it if it wont work at all
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
Apr 23, 2009 | Sony RDR-GX355
After recording the DVD player, wont play on any other player
I have seen this on other players as well. What happens is the media your recording on is either too slow for the player and the player is recording faster than the media is supposed to handle. For some reason it works on the machine it was recorded on but nothing else.
Solution: Get media that matches the speed of the player.
If this is not the solution let me know I will get you one.
Rob
Jan 09, 2009 | Sony RDR-VX525 DVD Recorder/VCR
Nov 12, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
