Question about Hotpoint RVM1435 Microwave Oven
Sharp half pint
Hi, I have a problem with a Sharp half pint microwave. I bought off Ebay- got here and plugged er in, it came on,when I set the time to run something "popped" in back now won't come on at all. Could it be a fuse? I have older recepticles and had to use an adapter so figure that's it. Caused the fuse to blow because no ground. HELP
  • Sara Gaines Aug 11, 2007
    Also, where is the fuse located?????
  • Sara Gaines Aug 12, 2007
    Hey jsrock- I cannot seem to find the fuse!! I followed the line from cord and saw nothing that looks like a fuse-could it be the green thing UNDER the micro ? If you could-post a pic. Thanks, Stormie
  • 5,911 Answers
The fuse should be located on an input line filter board INSIDE the microwave. You will need to unplug and remove the outside case to get to it. Simply follow where the power cord comes in and you should see a fuse mounted on a small circuit board somewhere. This is the line filter. The fuse should be a 20 amp appliance fuse that you can purchase at any hardware store. DO NOT attempt to re-energize the oven with the cover removed. There are dangerous voltages present in the high voltage circuit (about 13,000 - 14,000 VAC). Put the outside case back on before trying an op test. Let me know if this helps.
Posted on Aug 11, 2007
How to make rice in mwg9115sb?
I hope this will help I have a Panasonic which it gives you a guide for rice :
Basmati 250g low 10-12 mins
Easycook White 250g on High
Use 600ml (1pt) to 800ml 1 half pints boiling water. Cover and place on turntable.
May 31, 2014 | Emerson MWG9111SL Microwave Oven With...
Blinking electronic display on microwave
see the cause and proceed according. God bless you
but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Sharp Half Pint Microwave Oven
The digital display no longer works on my sharp half pint microwave r120d. How can I fix this? thanks in advance.
On this model, it's usually not economical to repair, but in most cases it can be repaired for $39.95. Details are here.
Aug 16, 2011 | Sharp R-120D Microwave Oven
Carousel II half-pint need the turntable glass
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Mar 26, 2011 | Sharp Microwave Ovens
I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
Here's a link to the parts listing at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
The list also includes helpful schematic diagrams that you can print for future troubleshooting.
if you need further assistance, please post back and let me know. I hope this helps you.
Nov 03, 2010 | Sharp R-120D Microwave Oven
Sharp half pint microwave wont heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Sharp R-120D Microwave Oven
Toshiba ER-684 microwave time setting?
clock - clear - enter time - clock
Mar 31, 2009 | Microwave Ovens
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Dont know how to get it working
You may need to open and close the door first.
Press CLOCK > 1 > 2 > 3 > CLOCK.
Let us know if this doesn;t work. You may have a bad door switch or mount.
Nov 30, 2008 | Microwave Ovens
Hotpoint RVM1435 Microwave Oven Logo
406 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
