Question about Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pw1 capacity What is the load capacity for the whirlpool ghw9150pw1 washer
SolutionGuy
  • 331 Answers
SOURCE: Error F2
Kap, yes I have a manual for your machine. Unfortunately, FixYa has policies in place that forbid me from getting it to you through their website. You can try contacting me using my user name at hotmail, though.
Posted on Oct 28, 2008
App King
  • 55 Answers
SOURCE: Whirlpool Ultimate Care II LSQ9564J Top Load
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Posted on Jul 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washer model number ghw9150pw1 code f
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
tbirdfan1
  • 3051 Answers
SOURCE: WHat is the capacity of
Hello there
  • Washer Type: Washer
  • Load Type: Top Load
  • Volume Capacity: 3.2 cu/ ft
is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
Posted on Jan 21, 2011
  • 5159 Answers
SOURCE: I have lost the paperwork
The Whirlpool Ultimate Care II LSQ9564J has a capacity of 3.2 cubic feet. Manuals for several of these washers are available from Whirlpool support: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?form_state=literatureSearch&context=&siteCd=WHRCOM&form_state=literatureSearch&searchTerm=LSQ9564J . The direct link for the English version of the manual for the LSQ9564JQ0 is: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203953953.pdf .
I hope this helps.
Posted on May 30, 2011
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
What is Wrong with my whirlpool front load washing machine,Mod.#GHW9150PW1?
f06 relates to a motor fault....easiest fix is to replace the motor......
cheaper on ebay........cheers
Oct 13, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pw1 whirlpool front load duet washer manual
https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211
Dec 07, 2011 | Washing Machines
Whirlpool front-loading automatic washer problem
yea replace the ccu and the mcu more than likeley the mcu will do it tho
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Screw stuck in door seal drain hole Whirlpool Duet GHW9150PW1
Magnet my friend :)
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error F2
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
