My frigidaire washer #FWT449GFS1 does not spin or agitate in any of the cycles. we checked power to the motor per instructions and we have zero volts on 4 pin plug between pins 2 and 4. Instructions
We checked power to the motor per instructions and we have zero volts on 4 pin plug between pins 2 and 4. Instructions state that if the meter reads zero then check the motor thermal cut out. Not sure how to check the motor thermal cut out-where is it? All other switches are working.
  • 1028 Answers
SOURCE: Drum won't spin.
ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Posted on May 01, 2008
  • 21 Answers
SOURCE: trying to understand the continuity check for F06 error
When you do a continuity check you do not have it plugged in. It is best to unplug at the motor so there is no feedback.
Posted on Jul 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirpool Duet Washer
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have a Frigidaire FTF530FS washer which is new.
Hello & Welcome to FixYa
If it is a brand new washer then it's better to get this repaired under warranty. The problem is with the door lock assembly that is bad and needs replacement. The drain filter pump assembly located inside the bottom front access panel seems clean, timer motor seems to be working fine. Please get back to me if you have any other questions.
Kevin
Posted on Jun 13, 2011
tbirdfan1
  • 3051 Answers
SOURCE: Frigidaire Gallery washer motor runs only counterclockwise
Hello there and welcome to fixya
this is due to reverse polarity that is caused by the machines electrical cord has been installed backwards or the plug in on the wall is wired backwards
So what you are going to want to do is first remove the cover that the plug in on the machine and look at the wiring and it should be marked what color or wire goes where IF it is a 3 wire only switch the 2 outside wires meaning the one on the left will be switched with the wire on the right ok the middle wire is the ground wire and does not need to be switched,
IF it only has 2 wired simply swith the position of the 2 wires by putting the one that is on the left on the terminal on the right and the place the terminal on the right on the left ok
Hope this helps
Best regards
Posted on Mar 16, 2012
Testimonial: "Michael, thanks for sticking with me on this. It's solved, and sadly (though probably not unexpectedly) user error was the issue. I thought I had the connections correct, but when running the resistance test, I realized that the 21 connector was on the 21a tab. Switched to it's proper position, and the machine is going back and forth as it's supposed to. Thanks again!!"
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
I have a Frigidaire FTF530ES1 front load washer that doesn't spin or agitate. The door lock light comes on and I don't think it is that. It fills with water, then you can hear the clicks for each cycl
Good Morning Vickie,
I understand that your Frigidaire washer, model# FTF530ES1, will not spin or agitate. I also see that the door lock light came on so you checked the door latch, due to it not unlocking right away. Now, you have removed the back panel and restarted the cycle, to find out that the motor is not coming on. There is a possibility that it could be the motor, or it could be something completely different that is causing your washer to not spin or agitate. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it is not spinning. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Spin/rinse cycle quits
it may be an intermittent door lock switch. i believe on your model when you remove the front access panel you will find a pair of wires in a plug with nothing attached to them on the r/h side where the wire harness runs. when you are in the spin cycle, check with a multimeter for 0 volts across the 2 wires. if you are showing 120 volts, then your door lock is bad. if yours has never been changed it actually has been updated to a new style. costs about $120.00 for the part. instructions should come with revised part
Aug 20, 2009 | Washing Machines
Installed a new timer in my frigidaire model#fwt449gfs1 now it will not enter final spin
check the motor controller for proper operation.
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
