Hydraulic floor jack
Jack will not stay up.
  • 7,627 Answers
Wrong Category
Posted on May 08, 2013
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
How does a floor jack work
Place jack under what you want lifted and close valve and put rod in jacker and jack up till your height is good,to let down turn valve counterclock wise.
Sep 13, 2012 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
My floorjack will not stay up?
About every 15 years, they need to be rebuilt
Have to find a hydraulic jack repair shop in your area
Jun 15, 2012 | Cars & Trucks
How do i replace motor mounts
get yourself a car(Hydraulic) jack(more commonly know as a floor jack), place it under the motor(more precisely, under the oil pan) place a 2x4 on top of the jack, and jack it up. JUST enough to remove the weight of the engine from the mount/s Then unbolt the old, and replace!
May 30, 2012 | 1990 Buick LeSabre
How do you fill a ac delco hydraulic 3 ton floor jack model 34123 with hydraulic fluid
DONT KNOW WHO BUILT THIS JACK- AC DELCO JUST PUT STICKERS ON IT. TYPICALLY YOU REMOVE A PLASTIC SCREW IN PLUG OR A POP IN RUBBER STOPPER FROM THE TOPSIDE OF THE CYLINDER. WITH THE JACK ALL THE DOWN, FILL IT COMPLETELY UP AND IT SHOULD WORK. SOMETIMES THEY GET AIR IN THEM - JUST LEAVE THE PLUG OUT AND JACK IT UP A FEW TIMES, THEN INSERT PLUG. USUALLY 10 WEIGHT HYD OIL. OR "JACK OIL" AT THE STORE.
Mar 26, 2009 | Plumbing
Need a lift
hi, i always recommend using a lift kit for safety but, you can use a hydraulic floor jack to lift as well. they are really strong and sturdy. i would recommend using one hydraulic floor jack on each axle.
Mar 04, 2009 | 1995 Dodge Dakota
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Placement of jack beneath solstice
the best place for floor jacks is either under the rear axle or on the spot where you would place your OEM jack that came with the car your owners manual should have a diagram that shows you where these spots are.
Aug 28, 2008 | 2008 Pontiac Solstice
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
