Question about LG Cell Phones
Lg360g sim lock code 1
Sim lock code-1
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
on Jan 21, 2010 | Cell Phones
Sim lock code 1 samsung
You can unlock the sim lock code by purchasing unlock code from any vendors online like TheUnlockArena.com
Nov 12, 2013 | Cars & Trucks
Tip
Lock Code, Pin Code & PUK code
Lock code: 1. 5 digits, Used to prevent unauthorized access to certain functions on the phone 2. Where: Tools > Settings > Security > Phone & SIM 3. Default: The default lock code for Nokia Series 60 devices is 12345. 4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you. PIN code 1. 4 digits, an optional 4 digit code to protect your SIM 2. where: Tools > Settings > Security > Phone & SIM 3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code PUK code 1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
on Jul 30, 2007 | Nokia E61 Smartphone
Sim lock
hi there are two types of sim lock one is Sim locked with security ,other is Sim locked with network .if your Sim is locked with network then you can use codes to unlock the mobile .you can get the codes from here superunlockcodes here they ask the following details before rendering the codes they are
1.mobile model
2.country from where you brought the mobile
3.provider to which the mobile is locked
4.imei number of the mobile
finally they will send you the unlock codes once
you entered the codes in your mobile as for the instructions provided by them
then your mobile get unlocked and it will accept other network sim.
Jul 20, 2011 | Sagem my201X Cellular Phone
Don,t know code for simlock
There are two types of Sim lock ,
1. Sim locked to Network
2.Sim locked with security code,
if the Phone locked to Network means get the Unlock code from here
Superunlockcodes and get the Free unlocking instruction from here
Mobileunlockguide and Unlock it...
If it locked to security code means get the master reset code from service provider reset it.
Jul 09, 2011 | Health & Beauty
I have 1 samsung sgh-f270, and it's puk-2 is locked. plz unlock it
PUK stands for personal Unlock code. This is not a lock code on the Phone. This code is a lock on the sim. When you enter the PIN number wrong thrice the sim gets blocked. PUK code is needed to unblock the sim. To get the PUK you need to contact your sim Provider (Network Operator. PUK -2 come when the PUK -1 is also entrered wrong. you need to cotact your Netopwrk operator.
May 11, 2009 | Samsung Cell Phones
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
Cell Phones Logo
80 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
