Question about Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
Louder my pump is making a loud noise while running its only a year old. Use to not be able to notice it was running ran so smoothly
    Top Expert:
  • Intex Master
  • 6,498 Answers
Replace pump motor
Posted on Apr 27, 2016
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
20+ year old Gould 1/2 hp jet pump in basement pulling my water from a deep well. It has become very loud whenever it turns on. Is there a way to lubricate it? my plumber says no...leave it alone. but...
Any pump that makes more noise that a small hum when operating is going out. Either the windings or a bearing is wearing out.
I would suggest you get it fixed by a motor shop or replaced before an emergency presents itself.
Rod
US Parts Center
888-521-6183
Feb 20, 2013 | Pool & Spa
2004 town and country whining noise louder when turning the steering wheel
Bad steering rack & or steering pump
Try flushing the fluid, as you should be doing every 3
years on all vehicles
After that-- have to diagnose & start changing parts-- if
you don't like the noise
Nov 23, 2012 | Cars & Trucks
Have loud noise from engine,gets louder w/more rpms.it is an automatic,60k miles.no exhaust or muffler problem.
Serpentine belt tightener pulley bearing was bad, made a loud noise. I replaced the pulley (jobber part) and the noise level was reduced enough to notice the waterpump was also making a noise ... more revs = louder noise. I am now replacing the water pump. (approx 60k Miles too).
Nov 22, 2010 | 2004 Toyota Corolla
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I replaced the brake, brake stator, and snubber ring on a Maytag MAV7650AWW top load washer. Now, when it is running it makes a loud grinding or humming noise. Nothing appears to be leaking. I ran it with...
most likely a bad water pump/remove belt and turn pump by hand , you'll be able to tell if its the pump by the way it turns,should turn smoothly in both directions
Mar 06, 2010 | Maytag Atlantis MAV7551 Top Load Washer
My 1986 Camaro Z28 has a loud ''toc, toc, toc'' sound when driving. It is not an exhanust leak nor clutch problem. The clutch and the water pump have been replaced. The sound gets louder and faster when I...
could be a variety of problems start-- w/head problem bad --lifter rocker,valve,valve spring,spark plug-wire -lower end/rod knock-bearing-wrist pin-piston/fan-pulley
Oct 23, 2009 | 1986 Chevrolet Camaro
5.5 Briggs & Stratton push mower running too loud
It could be the govenor spring. Get the model number, type and code and take it to a small engine parts store and get a new one. A new spring will slow down the rpm's and it wont be that loud. Make sure you remember how the spring was hooked up.
Let me know if this helps.
Thanks \
roundo4
Aug 25, 2009 | Garden
We mistakenly ran our 2 year old kitchenaid through a cycle
It's possible. A pump like that should never be run dry, especially if it ran dry for an extended period of time. Does the noise go away as more water moves through the system? If not absent then less?
Jul 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My challenger 3/4 pump has started to sound louder and louder.
Replace the motor bearings before they fail completely and ruin the motor.
Jun 07, 2009 | Pentair Challenger 3/4 Hp In Ground Pool...
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Logo
55 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
