Question about Planet Audio P9745B / P9740 Car Video Player
Wiring harness how and where do i get a wiring harness for my planet audio multimedia player
Where can I find a manual for p9715b
http://www.retrevo.com/s/Planet-Audio-P9717B-Car-Videos-review-manual/id/23652ci668/t/1-2/
Mar 30, 2015 | Planet Audio P9717B / P9712 Car Video...
I bought an planet audio CD player and I don't know how to begin with what colors go to what
best thing i can advize you is take the cd player to maplins or halfords tell them what car you have got and they will give you the right leads to join on to the manufactures leads so it is just a matter of pins in pull radio out that you wish to change connect universal leads to loom push cd player back in without jamming wires and away you go also ebay is pretty reasonble on audio leads if you know which 1 u want hope info is usefull
Feb 11, 2015 | Planet Audio Car Audio & Video
Wiring diagram for P9720
Planet audio 9720 screen blank bit button light up wat I need to do to fix it
Mar 18, 2014 | Planet Audio P9725B / P9720 Car Video...
How to display clock on a planet audio p9745b
bummer - cant find any manuals online about this receiver. Maybe hold down the volume down and see if the option becomes available?
Jan 03, 2013 | Planet Audio P9745B / P9740 Car Video...
Were can i buy a wire harness plug @
ebay, walmart. i would go thru amazon.com tho you can select your car model and they will send you the wire harness you need that will literally be plug and play instead of having to cut wire and put them all together.
Mar 27, 2011 | Audiovox AV1510D (Brand ) Car In-Dash...
I was hooking my Planet Audio P9745B up in my 2000 Honda Accord and it said Warning Video something so it wouldn't show but you could hear the movie and then it showed up on the screen. So i put everything...
Sounds like there could be a shorted wire possibly power but what sounds like happened is the unit grounded out and blew the cigarette lighter fuse. Check fuse box for blown fuse, if this is the case I would suggest pulling radio out and having the wire harness for the radio professionally connected and inspect all connections
Aug 23, 2017 | Planet Audio P9745B / P9740 Car Video...
I want to install am/fm cd cassette player into my honda odyssey lx model,by removing the casste player ,harness connectors are same
No the wiring harness are not the same, if your factory radio is standar audio system this is the part # Metra 70-1721
Jan 07, 2010 | Buck Honda Odyssey 2004 Car Stereo/radio...
Hooking up a multimedia disc player boss
Sorry, you must have a harness. No harness, no power. Unless you try to hardwire the unit, but that would mean you have to solder wires to the inside of the player and take out the jack for the harness. A very dangerous thing to do. It could cause a fire if not done perfectly. Without knowing what kind of player it is, model number and make, nobody can tell you how to hardwire it.
Jun 29, 2008 | Car Audio & Video
Planet Audio P9745B / P9740 Car Video Player Logo
32 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
