Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Camcorder won't playback most Hi8 tapes
I purchased a DCRTRV285E and was told that it could record in PAL but playback NTSC tapes. It doesn't pickup the timecode of most of my old HI8 and 8 mm tapes. My Hi8 and 8mm tape collection is about 15 years old. Any help would be appreciated, thanks.
  • Anonymous Mar 26, 2014
    I bought a TRV280 camera to transfer old home videos on 8 mm tapes into my computer but even with the right drivers installed the camera wasn't recognized by my computer. But my biggest concern is that the camera itself refuses to playback any of the 8mm tapes I placed in and just shows a blue screen. Is the TRV280 incompatible with 8mm cassettes? And if that's true which camera can transfer this footage?
The literature states that the 285E is backwards compatible.
Posted on Aug 13, 2007
  • 169 Answers
May be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Posted on Aug 11, 2007
SOURCE:
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
MY SONY DCR-TRV140E WILL NOT PLAYBACK MY OLD VIDEO8 (PAL8) TAPES?
Vista should be able to download this without any issues as it already includes the drivers. i was able to do this with my sony dcr-trv250 painlessly over the ieee-1394 (firewire) port using the DVD capturing bloat-ware (Ulead DVD creater) Toshiba had already installed for me. My toshiba satellite is running Vista Home Premium.
as regards analog hi8 playback, the product manual for the 250 says that this is NOT supported, i.e., it CANNOT play back analog hi8 tapes. Also, i wonder if PAL would be supported here in the US (assuming you're in the US, of course). I would expect only NTSC support. but it's a moot issue, since it doesn't play analog
Oct 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
I have vertical multicolor lines
I think u are using pre recorde cassetts that were recorded on any other camcorder..
Samsung D363 supports ntsc not pal....
and the cassetts recorded on pal must have prob with ntsc based device...
all u have to do is record cassette with the same and then test playback...
Feb 25, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
691 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
