No perfect drying stopped and H6
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
SOURCE: washing machine error code h6
hi,
seems a spade connector had dislodged itself from the back of the machine reattached and all works seems it was a heat problem.
Hope this helps
please give me a FixYa rating if the solution works.
Thanks
SOURCE: Daewoo DWD G1243S washing machine
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
