Question about Toro Lawn Mower With Toro Power Tools
TORO LX 425 MOWER - STARTS AUTOMATICALLY
I stored my mower for the winter and took the battery out. The battery was charged two or three times with the most recent being in May of 2013. The mower worked great last fall, but now that I need it, it does not work. I attempted to hook up the battery to the mower (positive first, then negative), but, after hooking up the positive terminal, and attempting to connect the negative terminal, the terminals started to spark. As they sparked, the engine attempted to start every time it made connection with the terminals. After several times it sparked, it does not spark anymore, does not have any power to the mower, and does not try to start anymore. The key ignition is in the "off" position. I am at my wit's end and can not figure out why this is happening and why it is trying to start by itself. Hooking up the battery is an extremely easy thing to do, but obviously my mower wants to cause me headaches. Please help with a resolution to my problem. Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toro Master
  • 969 Answers
By trying to start it so many times sounds like you blew the fuse. your problem sounds like it started with a bad solenoid.take it off and test. if it is bad replace it. put a new fuse in and it should start as it is supposed to.
Posted on Mar 09, 2017
steve_lima
  • 181 Answers
SOURCE: 6.0 toro mower won't start but has plenty of spark.
does it have a two cycle or four cycle engine on this unit????
if it's two cycle the piston and rings might me burnt and scored....
if it's four cycle,you need to check to see if the flywheel key is broken.didyou happen to hit some thing the last time you mowed????.to check the flywheel key you need to take off the blower housing so you can take off the center bolt that hold the flywheel on.you'll be able to see if the key is broken or not...
Posted on Mar 10, 2009
  • 398 Answers
SOURCE: No compression release; can't turn over
well if you can pinpoint the leak you may be able to repair it. if you test the compression in the engine you can tell if the rings or valve are bad. you need a specail tool to test compression, $45. let me know what you find
Posted on Mar 20, 2009
  • 86 Answers
SOURCE: Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
Posted on May 16, 2009
  • 41 Answers
SOURCE: turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
Posted on May 19, 2009
harlan301
  • 205 Answers
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Posted on Oct 23, 2009
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
2013 electric start lawn boy wontons start
If it sat over the winter, the battery probably needs charging or replacing. If you hear a clicking sound when you try to start, that usually means the battery is low.To eliminate a seized engine problem try starting it with the pull start. Most small batteries will only last three to five years on average. The batteries are pretty straight forward to replace if you can handle nuts and bolts situations. Hope this helps.
Mar 11, 2016 | Electric Garden
My car, since cold weather will not start. jump start three time- sent to Chevrolet. what
Check the battery is holding the charge, Check the alternator drive belt is tight, have you the right grade oil for winter.if the weather is very cold make sure its under cover.
Jan 05, 2016 | 2013 Chevrolet Malibu
Cub cadet 22 hp zeroturn wont start after storing for winter. Replaced battery, it looks like its not getting enough power to start. It will not turnover all the way.
charge and test the battery. the battery may be no good after sitting all winter and may need to be replaced.
Feb 21, 2013 | Garden
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
How do you store lawnmower for winter? do you
mix a fresh gallon of 89 octane with a fuel stabilizer. run for a few minutes. the battery will need a trickle charger.
Nov 06, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Mower sat over the winter. Turn key and nothing
Neither ... charge the battery first. New doesnt necessarily mean fully charged.
Charge it with a properly sized charger for 24 hours then check with a volt ohm meter.
May 01, 2010 | Garden
My lawn mower wont start . do the batt need to be charged
Is this a serious question. If you have not run the machine all winter and did not take the battery out when you stored it than yes charge the battery.
Apr 28, 2010 | Garden
Black & Decker Cordless lawnmore CMM 1200 - battery
I bought my B&D cordless mower CMM1000 (very similar to the CMM1200) in April 2003. I made the mistake of following their instructions and stored it inside unplugged the first winter. Never again! The battery would not hold a charge April 2004, but was covered under warranty. Since then, I've left it trickle charging in the shed year round, including cold winters. No problem since then with the battery, which will last about 5 yrs before you need to replace it.
Nov 29, 2008 | Black & Decker 19" Electric Lawnhog...
B&D battery lawn mower - winter care
Hi, it depends on the age of the battery. if it's new no ploblem depending on the age you may have to give it a trickle charge in jan.
If this doesn’t work for you please write back. Thanks,
Nov 19, 2008 | Black & Decker 19" Electric Lawnhog...
Toro Lawn Mower With Toro Power Tools Logo
78 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
