Question about Symbol MC3090
Trouble Obtaining IP Address
I'm using an MC3090 and trying to connect to a router via WEP 40-bit encryption. Once I connect to the network and try to request an internet page I receive an error in my browser: "The page cannot be displayed . . . Cannot find server or DNS error." The barcode scanner seems to be connected to the LAN and is displaying an excellent signal strength. When I go to *wireless status* -> *IPv4 Status* I notice that my IP Address and Subnet are empty for about 20 to 40 seconds, then they flash values on the screen for 2 or 3 seconds, then the lease expires and the values go empty again. The cycle is continuing on indefinitely, 1) lease an IP, 2) IP expires, 3) renew and repeat. The router and wireless connection both work just fine on my MacBook Pro.
"obtaining IP address"
May I suggest to temporarily have no wep/wpa set at all, go for open and see if that works for the tablet.
If not, try changing the SSID of your wireless network.
Also, there may be insufficient IP's in the DHCP pool.
Or, maybe a MAC filter is set.
Nov 09, 2013 | Samsung N8020 Galaxy Note 10.1 16GB WiFi...
Want to set up WEP encryption, but the router doesn't seem to accept it.
You have to use a static IP or PPPoE IP Address in order to enable this WEP function. Use the ASCII settings to enter text. Look at the restrictions noted.
Oct 23, 2012 | D-Link Vonage-enabled Wireless Router...
How do I determine actual threats to my network while reviewing my wireless/network Router's Event Log?
Logs are meant to see the activities handled by your router. However, to determine any threat you can check for the IP address of the devices you have connected to your router. You can determine if any one else is trying to access your router by their ip address only.
Note down the IP address for all the devices that you have connected to your router. Than match the your devices IP addresses with IP addresses you found in the logs.
Matching IP address: Means your devices accessing the router. Unmatched IP Address: Someone else's devices trying to access your router.
You can always add security by using WEP/WPA2 key security. For further security you can encrypt the keys.
Jul 06, 2011 | NetGear WNDR3700 Wireless Router
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect to wifi in my ipod touch
Change the router encryption or create an encryption as WEP using your Zyxel router.
The connection in your college is maybe unsecured or no security?
- Try also to check the settings of your router make that unsecured or configured a WEP encryption to the router.
- Turn off the MAC filtering of the router (Under advance settings)
- Disable the wifi-protected setup of the router (Under advance settings)
- Refresh the network list before reconnecting to the network.
Note: As we try WEP encryption to some of the router, the IPod can connect to the network.
Mar 08, 2009 | Zyxel P660HW-D1 Router
Cannot connect to Internet
Set the "Mode" on the "Details" as "Infrastructure" if you are connecting to a wireless access point/router
SSID is case sensitive, ensure that you have it entered exactly the same as it is on router
On WEP Key, use the 10 Hexadecimal key (for 64-bit WEP) or 26 Hex if (128-bit WEP) that is set on the router (0-9 and A-F characters on Key 1. Key 1 is selected as the default network key on the router).
Also, ensure that the DHCP is enabled on the router so it will issue an IP address to your device.
Once everything is set, power cycle your devices to synch your wireless connection (power off the router and the device and turn them back on in that order).
Hope this helps.
Feb 10, 2009 | Denon ASD3W IPod Networking Dock Docking...
LG KC910 connecting wifi to my home internet
I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
Feb 02, 2009 | LG KC910 Renoir Cell Phone
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
Symbol MC3090 Logo
35 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
