Question about Kitchen Ranges
Jenn air model
I need the membrane switch, part # Y04100040
2 Suggested Answers
  • 464 Answers
SOURCE: jenn-air sce30600 - replace door lock switch
Hi Don, the part you need is 71001129 and is #13 in the attached breakdown. Hope this helps you get it apart.
Posted on Nov 08, 2009
Read-out shows F3
On a GE microwave, "F3" means a bad membrane keypad.
You can order a membrane keypad here and install it yourself according to this handy illustrated guide, or we can install it for you.
If the keypad is not available separately, you can order a control panel frame assembly here, which comes with a new keypad already installed.
But since this was posted under Jenn-Air, that confuses the issue. If yours is a Jenn-Sir, please post a new help request here on FixYa and include the full model number from the tag, or contact us for a free estimate and tips.
Aug 18, 2010 | Jenn-Air Microwave Ovens
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Need free help how to fix F1-8 error on Jenn Air oven
Hi
I have found the codes you are looking for.I hope this get you in the right track. Let me know how it goes.
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)Thank you for writing to fix ya.
Best regards richard
Feb 28, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Failure
Code
JENN-AIR
Failure
Code
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
My Jenn Air 30 in oven
For Jenn-Air ranges, this is a fault code for a defective Electronic Range Control (ERC) and/or membrane (keypad). It is usually a bad membrane that causes this problem. If the membrane has a small ribbon cable connecting it to the ERC, you can sometimes disconnect it, clean the connections, and reinstall to correct the problem. The problem may also be as simple as a button on the keyboard stuck somewhere. Worst case scenario: you will have to replace the entire ERC and membrane altogether. For pricing information, you can find replacement parts at searspartsdirect.com or repairclinic.com. Just type in your model number in the search menu and there will be a parts index for you. The membrane and ERC are usually sold separately. I hope this helps you.
Mar 02, 2008 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn-air ww30430p
this can be the light unit or the power unit supplying the voltage to the light unit. both cost about$150 each. I need a wiring diagram or know the voltage that comes out of the epower supply
Nov 14, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
