Question about Hayward H-series Electronic Gas Pool Heater H400
Heater does not ignite. Not sure if it is not getting gas or if it is not igniting.
    Top Expert:
  • Hayward Master
  • 6,465 Answers
See if gas valve has voltage if so see if gas pressure is ok if ok see if ignitor has voltage or ohm it out should be about 78 ohms disconnected
Posted on Mar 19, 2016
5 Suggested Answers
  • 139 Answers
SOURCE: Hayward pool heater Model CZ 250 will not ignite
if ignitor sparks i'd say its okay, more likely a gas valve problem.are you sure gas supply is on and purged of air?make sure gas valve(the one gas supply threads into) is in the on position
Posted on Jun 21, 2009
  • 12 Answers
SOURCE: hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Posted on Jun 25, 2009
  • 760 Answers
SOURCE: Hayward H-Series 200k BTU Millivolt Heater -
You didn't say what terminals you jumped, but I assume it's the flow switch, or it could be the thermostat. The flow switch is located on the piping inside the heater. This flow switch is very important because if you didn't have water flowing through the heater it would oveheat. These do go bad or sometimes just get stuck depending on what type they are. If it's the thermostat, mounted on the front pane you're jumping, then either it or it's expansion bulb is faulty. GOOD LUCK Who needs a heater in JULY?
Posted on Jul 03, 2010
Testimonial: "Thank you, Yu have given me plenty to look into..."
john224
  • 1378 Answers
SOURCE: I have a Hayward 300 pool heater that has an IF
Thank you for posting your question here on Fixya.com.
Use a manometer to read inlet and outlet gas pressure on the gas valve when it gets the 24V...I'll bet your valve is bad and not opening therefore no pressure will be read on the manifold side of the valve. Reading gas pressure on the inlet will verify there isn't an issue with the gas supply.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Light flashes 4 times
ignition failure. insure air pressure switch closes, hot surface igniter is getting 120volts. check continuity on hot surface igniter, make sure all gas shut off valves are open and gas valve is turned on. make sure there is no blockage in the exhaust
Apr 18, 2014 | Goodman GMS90703BXA Heater
Ignition lockout
Make sure all gas is turned on to the heater, ignition lockout can be one of several things, the majority of the time its a control board but, it could also be water in the heat exchanger pot, which would keep the ignitor from working, or a bad igniter.
Feb 20, 2014 | Pentair Mastertemp Heater
Code 1F
"IF" or" Ignition failure", simply means you heater didn't fire. Be sure your gas is on,and if on propane be sure there is at least 30% in the tank (and the valve is open).Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Oct 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
First of all when trying to ingite gas heater there was a igniting sound but no actual ignition of heater and now when trying to inginte heater there is no sound at all of ignition. the brand is a Jandy...
if hooked up 120 volt make sure to turn the power conversion board plug to 120 volt come wired for 220 volt if you didn't the ignitor isn't heating up enough make sure gas pressure is good also
Jul 25, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
New installation liquid propane fueled will not fire. 120 volts is wired correctly. Checked for lp pressure to valve - is ok.turn switch on and see led blink once then hear igniter "clicking' for several...
You can try swaping the leads (hot and common) If this is a lo nox heater be sure your pipe size is correct. The new lo nox rely's on gas volume as well as pressure. Also be sure your heater is wired for 110v or your spark won't be hot enough with just a 110v feed, but if your getting 24v at the valve that is probally OK.
Jun 25, 2010 | Pentair MiniMax 100 Aboveground 100,000...
I have a Laars Lite2 gas spa heater. I just replaced the Fenwal Electronic Eignition. When I turn the power on it starts the start-up process, the gas starts to flow, but no clicking of the igniter, just...
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
Jun 20, 2010 | Jandy Laars Lt 250,000 Btu Heater
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
We believe we are to turn on the water electric button to start the heater. Directions say the light should go out when ignition occurs. It won't go out.
If your water heater has an electric element, as well as electronic ignition for gas operation, you may be getting them mixed up. One switch should show like a lightning bolt beside it,(that's for hydro use) the other will show a small gas flame beside it.(that's to turn on ignition for gas operation.)
If you only have one, my guess is it's for electronic ignition. When you turn that on, you should hear the water heater trying to ignite outside.("click,click,click) and then burner should ignite if you have your propane on. Get back to me with your model number of the heater, behind cover outside, and I can tell by that what you have as far as just gas, gas and electric, etc.
Apr 26, 2010 | RTO Atwood Water Heater - 6 Gal LP
Jun 18, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
66 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
