Question about Thermador Kitchen Ranges
Need discontinued burner valve for GCV36G
Looking to replace front left burner valve for Thermador gas cooktop model GCV36G. Part number was 20-09-138 (Bosch). Number printed on part is 8114. Model is from 1985 and was discontinued in 1990. Same part is used in Thermador models GCV36, GTH36, GTH36G.
    Top Expert:
  • Thermador Master
  • 35,531 Answers
You can try an appliance parts supplier. There might be a crossover to a current part
Posted on May 08, 2013
  • David Jacobs
    David Jacobs May 08, 2013
    Thank you, I have done that already and there is no current part. I need to find someone who has the part sitting in their inventory or someone who has used parts.
  • 213 Answers
SOURCE: Burner For radiant range
part number is 316224200 $ 116.40 at sears.com
Posted on Nov 21, 2007
  • 217 Answers
SOURCE: Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on Jul 11, 2008
  • 333 Answers
SOURCE: I am looking for the
Where do you live?
Posted on Sep 01, 2008
SOURCE: Need Bosch stand mixer's model number to buy replacement parts
Just some added information. The number you have may be a part number. I ahve the exact same number on my Bosch Universal Mixer. What i'm looking for is a new casing, mine is broken.
SOURCE: Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Posted on Sep 10, 2009
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
Just google the repair clinic and partselect,they are selling spare parts online..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Model RDSS30QW X-LO Burner Problem
remove 4 screws under the trim that surrounds the burner knob panel. They are on the underside and you will be looking straight up to see them.
Slide the trim down and off after removing the screws.
remove the burner grills and caps
remove the 4 brass venturis and you will then be able to lift the cooktop
the valves are easy to get to
May 10, 2007 | Thermador RDDS30 Dual Fuel (Electric and...
Kitchen Ranges Logo
154 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
