Question about Zeikos 57-in-1 USB 2.0 High Speed Memory Card Reader SD,... [ZE-CR201]
Zeikos memory card reader
Will not work, comes up as unknown device/device not recognized.
Computer wont recognize the camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 01, 2014 | Zeikos Vivitar ViviCam F128 Digital Camera...
Will not recognize card reader
Make sure Windows Update service is running, then unplug and replug in your USB cable. If it doesn't automatically install the driver for it, select the option to search windows update for the driver. This should fix the problem, or you may search windows update alternative updates for a USB update.
There are no drivers for this product outside of the windows USB drivers. Any website claiming there is a driver for it is more than likely offering a you a virus.
Mar 29, 2013 | Zeikos 57-in-1 USB 2.0 High Speed Memory...
Built-in memory card reader doesn't work
It's a common problem in a OS upgrade. Is your OS 32 or 64bit? Is that the only thing that out of service? In Device Manager do you show ANY Unknown Devices? Is the Card Reader Listed? post results.
Jan 26, 2013 | HP Pavilion g6-2210us Laptop PC
Pics wont down load to PC
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Apr 22, 2012 | Panasonic Lumix Dmc-fs12 black 12.1mp 4x...
TARGUS High Sped USB Memory Card Reader/Writer failure...
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 27, 2010 | Electronics - Others
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Driver for flash memory card for windows vista
Here is the solution for pen drive (you are must to have got acces to
Windows XP installed drive):
- copy usbstor.inf and usbstor.sys placed in WinXP folders (Windows\INF and
Windows\system32\drivers) on the some location on your disk.
- plug in device with Vista running
- when it is not recognized place to location where you saved these two
files above
- when you vista recognize mass storage device you will get information
about inproper INF section, and the second device will be unknown in your
device manager
- try to actualize driver for unknown device and point Vista to find driver
into your c:\windowsvistadir\ [x] with subdirectories
This problem may be because u have enable some security on ur memory stick if so try this driver
http://esupport.sony.com/US/perl/swu-download.pl?&upd_id=2159&SMB=YES
or you can also try this driver
http://www.developerfood.com/sony-ericsson-w850i-usb-drivers-for-memory-stick/microsoft-public-windows-vista-music-pictures-video/452f8fe9-82ee-47c2-ad6e-f2f3eccb6748/article.aspx
Nov 16, 2007 | Electronics - Others
Zeikos 57-in-1 USB 2.0 High Speed Memory Card Reader SD,... [ZE-CR201] Logo
Top Zeikos Cameras Experts
Steve
Are you a Zeikos Camera Expert? Answer questions, earn points and help others
