Homemaker hmxqb50-808gf water drain while washing
2 Suggested Answers
SOURCE: homemaker 5kg washing machine blocked drain
This farking chinese systems are so unstable.. homemaker is a pure chinese breed and suddenly they have comeup with so many products from no where with no backgroud R&D team or history... possible typical chinese company who hacks into foreign network for R&D work and produces its products.. well god bless i hope u get ur things fixed...which i doubt... such chinese company has no network or supply parts gurantee...they solely reply on stolen R&D work... i bought a system from them and sweared that never to buy cheap chinese products...cant trust those commies well good luck..
Posted on Jun 13, 2010
Homemaker hmwm 6000 cannot find a replacement belt
The Homemaker machine you have turns up little helpful information when searched. If all you need is a belt, you should bring the broken / worn belt (and all parts if broken in several pieces) so that it can be measured to determine the proper length and width, number of ribs, depth, etc. when you go to an appliance store or even autparts store (I have no idea what your belt looks like so I can't suggest one over the other). Many times, these machines have a spring-loaded pulley that is used to reduce slipping as the belt stretches / wears. This makes it possible to use a belt that is "close" length.
Mar 11, 2014 | Washing Machines
Where i can find the spare parts for Homemaker hmwm6000 6.0 xxxl washing machine
Ask your local Kmart store for Homemaker's phone number.
May 29, 2012 | Washing Machines
I have a homemaker hwmw8000 washing machine model, and it washes , but then stops before the water drains, and then it shows error 1
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
check water pump for blockage or faults
Jan 17, 2010 | Washing Machines
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
Homemaker HMWM8000 shows E2 error and will not pump out water
Maybe just a blocked filter?
If the waste pipe is clear and nothing in the filter, the pump is worn or faulty.
Remove waste pipe and lay it flat on the ground to drain.
Hope this helps
john
Aug 27, 2009 | Washing Machines
Homemaker 5kg washing machine blocked drain
Could the block be in the wall drain.............
Dec 04, 2007 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
