Question about Dell 5210n Laser Printer
I'm getting a 202.13 paper jam.
I have tried unplugging and blowing out the unit. There is no paper to be found anywhere. What should I try next?
  • 121 Answers
SOURCE: paper jam
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Posted on Oct 27, 2007
SOURCE: Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Posted on Apr 12, 2008
SOURCE: Reading "paper Jam" but no jam-no paper to be found?
what solution? and from another entry what is that strange symbol before the number 9?
thanks
mark
Posted on Apr 20, 2008
damanpreet_c
  • 69 Answers
SOURCE: carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 06, 2008
SOURCE: 1710 Printer
http://www.fastprinters.com/ProductDetails.asp?product_id=LEX-56P1826
Cheap sensor replacement
Posted on Mar 26, 2009
I get message to pull out jammed paper but I cannot find end of the paper to pull out
Try blowing the printer out with a can of compressed air. Tiny bits of paper will often get stuck in the "eye" of the optical reader that tells the printer that it has a jam. Compressed air can blow this debris loose.
Another thing to double-check is the paper tray. Remove the paper tray and inspect the place where the paper gets pulled into the printer. Sometimes you will find a sheet of paper stuck there that isn't readily apparent anywhere else.
Aug 03, 2015 | Epson PictureMate 500 InkJet Photo Printer
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
MFC8480DN shows paper jam tray 1 but no papers are found. Checked front, back and drum unit - no papers
Try unplugging the machine and leaving it unplugged for at least 30 seconds. May just need to clear the memory.
Ensure that you have checked the feeding trays, even a small piece of paper can make it read a jam.
Mar 17, 2015 | Office Equipment & Supplies
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Canon mp495 keeps jamming. Error code E3
After searching the net for help and trying many things like unpluging the printer, taking out the ink cartridges, blowing and hooving the printer etc etc and still not having any luck. I tried something myself and it worked.
This is what I did:-
I got several sheets of A4 paper and forced them into the printer just enough to get the rollers to bite. (Printer is off at this stage) Once the paper is in I turned the printer back on and the printer pulled the paper through and out of the front clearing the problem.
Well this worked for and I hope it helps someone else.
Bobthedodge
Aug 07, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Dell 5210n Laser Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
