Question about Garmin StreetPilot C330 GPS Receiver
Garmin 330 battery
My garmin stopped recharging. It still works but will not recharge, I have tried both the car charger and the one that connects to the computer. Any thoughts, In another posting you suggested a way to kick start the battery.
  • 12 more comments
  • R0BMAN Nov 26, 2007
    YOU NEED TO REPLACE THE BATTERY.POP THE SILVER TRIM OFF THE FRONT AND YOU WILL FIND SCREWS THAT ATTACH THE FRONT OF THE GPS, REMOVE THE SCREWS AND FOLD THE FRONT DOWN. NEXT YOU WILL SEE THE BATTERY, IT IS SOLDERED IN YOU WILL NEED TO UNSOLDER THE BATTERY AND RESOLDER THE NEW BATTERY IN. BATTERIES CAN BE FOUND AT A NUMBER OF WEBSITES FOR ABOUT $20.00 US DOLLARS.
  • Anonymous Dec 26, 2007
    My Garmin 330c works fine in every way, except it will not recharge on the car power. It charges just fine from the computer What can I do?
    Thank you
    davidilewis@yahoo.com
  • Anonymous Dec 31, 2007
    I received for Christmas a
    I received for Christmas a GPS 330 and the battery is low already. I had it plugged into the car while I was using it and now it says low battery. I don't know how to charge it. Cables came with it but no instructions and so I don't know if hooking it up to the computer is how to charge it or if I should leave it hooked up to the car when the car is turned off. Do I leave the computer on to charge it and how long does it take. any help would be appreciated.
  • Anonymous Jan 02, 2008
    My 330 does not recharge I would like to know where to buy a batttery
  • Anonymous Jan 09, 2008
    Garmin 330 was saying "low battery" . Now (although plugged into cigarette lighter) it just shuts off. It is new (x-mas gift). What to do?
  • Anonymous Jan 12, 2008
    How Long Should I charge my Garmin C330 using the wall charger when the battery registers low?
  • GRAM6 Jan 14, 2008
    my garmin c330 will not charge in the car while traveling?it has a full charge when i head out but after 4 hours it shows low battery,i was thinking the gps was supose to charge with the car adapter plug in.my will not charge.brenda
  • Anonymous Feb 14, 2008
    no idea how to charge the unit please tell me how?
  • lksb Jul 26, 2008
    car charger no longer charges the unit - this is a 6 month old unit
  • lmiller474 Jul 28, 2008
    My garmin is not charging when I put in into the cigarette lighter. What should I do?
  • elqman Aug 12, 2008
    Same prob. with the lithum battery.....Does not hold a charge...
  • winerchip Dec 09, 2008
    I have the C330 as well. Battery would not charge anymore, but the unit worked fine. Got tired of no battery, so I replaced the battery. The battery charges fine, however I don't get an antenna signal now. Does anyone have any thoughts?
  • Anonymous Jan 09, 2009
    We put the location in the garmin 330, and pressed GO and what appeared on screen was a triangle with a red question mark in the top of the triangle. Screen said low battery charging, therefore we could not get to our location to where we wanted to go.
  • 174 Answers
"my garmin c330 will not charge in the car while traveling?it has a full charge when i head out but after 4 hours it shows low battery,i was thinking the gps was supose to charge with the car adapter plug in.my will not charge."
There is a problem with the cable or the cigarette lighter power supply. If the cigarette is working then when you start the car the Garmin should turn on and when you turn off the engine the Garmin should shut down. If you are manually turn the unit on/off then it is not running off the cigarette lighter power supply. Check to make sure there is power coming from the cigarette lighter.
Posted on Jan 15, 2008
I actually had the same problem and at first I thought its the faulty car charger that stopped working so I replaced it but the problem did not go away, Then I bought replacement battery 15 mins of my time and I had my C330 up and running as it was brand new unit. btw I got the battery from megacapacity.com for 20$ and free shipping to Atlanta GA. The shipping took a little longer then I thought but hey it was free and I saved around 100$ money by not sending it back to Garmin
http://www.megacapacity.com/23903.html
Posted on Aug 14, 2008
Doing a web search, this appears to be a common problem, or defect? After 18 months my StreetPilot 340 battery is no longer charging. Garmin tech support claims this can be remedied by charging the device via the USB port or 120V AC charge adaptor. Neither worked. Seems many of us are stuck with an out of warranty device which Garmin will only remedy via a $250 mail in repair. I personally don't find this an acceptable solution.
Posted on Aug 11, 2007
    Problem Solver:
  • 5 Answers
I have this same problem as well. My battery is stone cold dead. It powers up fine via both the USB cable and the car charger, but the battery doesn't charge. In fact, when on either "charger", the little battery icon doesn't even show up to show that it's being charged. I think I'm going to try the solution in option #1, and purchase a battery online, if it looks easy enough. I opened up the unit a few weeks ago to see if it was an obvious short, and it looks like I might have to solder something to replace the battery, in which case I might end up frying the unit since I kind of **** at soldering. I'll try to remember to come back here and post what happened.
Posted on Aug 19, 2008
  • Tom
    Tom Apr 05, 2011
    Replaced the battery and it worked great... for a while... but eventually that battery stopped holding a charge as well. Replaced with another GPS from TomTom with free lifetime map updates.
I had the same problem with my C330. I was preparing to send it back when I thought of testing the output. I took the unit out of the mounting bracket and it was getting 12 volts. I put a very small amount of dielectric grease on the contacts and it now works perfectly. Worth trying!
Posted on Aug 16, 2008
I have a c330 that I had to RMA twice during the warranty period for this issue. (Or really, one very much like it. I had two units that would ONLY run on external power, the battery died completely.)
Now that it's out of warranty, I guess I'll just have to buy a new one if it happens again. I'm not paying $250 for service when I can buy a better unit brand new (nuvi 200w) for $200
Posted on Jul 27, 2008
Of course its not an acceptable solution. NO COMPANY today manufactures quality electronics. NOBODY. However, Garmin seems to be the "easiest" to use and most updated out of the various manufacturers.
Posted on Dec 07, 2007
  • 4 Answers
Garmin is pretty good about covering units beyond the warranty especially if the problem is long term and if you called in before for the same problem. I would call back and see what they say
Posted on Jan 16, 2008
Garmin approach G6 hand held yardage finder
I would say the battery is defective but make sure the charger is ok, you will need a DVOM meter to test the charger, it should have about 7-9 volts output unloaded.
Sep 22, 2016 | Garmin Approach G6 Golfing GPS
Have not used my garmin for a few months. I think the battery needs recharging but it will not turn on when i try to recharge in the car .????
It is possible that your cars 12v socket is not functioning, try using a different car charger see if it is functioning. If you find that the other cable is working in your car it may be your power cable that has died, maybe try using your computer USB port to power it see if the battery can get a charge.
Hope this helps!
Apr 14, 2011 | Garmin nuvi 255W GPS Receiver
GPS is 1.5 years old and it stopped working. It won't turn on, even when plugged into the car charger. Could this be a connection or battery issue?
It could be a battery issue - but that isn't likely. Disconnect the GPS from the car charger and connect to your computer via USB port overnight (8+ hours) and try again. The battery is "reconditioned" for lack of a better term, and will recharge again as in the past. If it happens again, repeat the procedure.
If still having problems, you should contact Garmin Support below:
http://www.garmin.com/garmin/cms/site/us/support
Please rate this reply if you found it helpful - good luck!
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin went dead after showing low battery and will not recharge
check charging cable or charger try using another one or try to recharg battery extranal charger
Jun 24, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Alarm goes off when recharging the battery.
try turning on ignition switch before hooking up charger, once charger is working turn switch off.
May 10, 2010 | 1992 Pontiac Bonneville
The battery died on my 03 diamante. when i tried to recharge it the car alarm started and wont stop to allow the car to keep a charge?
Only Recharge the Battery with both the Cables: Positive and Negative removed from the Battery.
With the Charger OFF the Battery - Reset your Alarm turning it OFF.
Then Disconnect the Battery completely.
Never Recharge a Battery while it is still connected.
Jan 20, 2010 | 2003 Mitsubishi Diamante
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery...
If the GPS's internal battery is allowed to discharge too far, it will not be possible to recharge with the card charger, until it is brought up to a certain level. Connect the nuvi to a computer with USB cable overnight. This will trickle charge the internal battery to a level that will allow the car charger / cradle to keep the GPS charged from that point on. Anytime the car charger fails to recharge the internal battery, the USB charge method will have to be performed first.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
Will not take a charge from either car charger and motorola port
YES the battery is sogged AC by passes low voltage circuit.9 battery) Get a new battery fitted and all should work again for you
Jun 19, 2009 | Garmin StreetPilot c340 GPS Receiver
Battery dead garmin st-finder. Recharge / replace???
if that gadget of yours have a good battery, it would charge, but it does not then better buy a new one. however, pls try checking the battery first, the charger, and the output of the battery. The output voltage should meet the requirment of the gadget.
May 25, 2009 | Garmin StreetPilot C330 GPS Receiver
How can I recharge the battery on my Garmin Nuvi?
Just use your USB cable that came with it to connect it to your computer. It will charge just fine. You can also use a cell phone charger that has a USB connector. A lot of cell phones use this type of charger now and the charge will work fine with the GPS>
Apr 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
930 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
