Question about Whirlpool Washing Machines
Whirlpool WFW9050XW00 stops at mid cycle
Hi, My washing machine stopped at mid cycle, I thought it was the control board so I went ahead and bought one, after I installed it the same problem persist. When I press start, the door just locks and won't start (door can only be opened manually), I have to unplug and plug to reset. I tried the auto cycle test on the manual, it just fills the tub and drains the water out and motor keeps running continuosly for a number of minutes. I can't stop the test either, to do so I pull the plug. Thanks. Jojo
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    SOURCE: GE SpaceMaker washing machine does not stop filling.
    try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
    Posted on Mar 27, 2009
    dh1200s
    • 335 Answers
    SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
    Hey Cameron,
    I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
    P1 Motor Control common
    P2 Torque (to Motor Controller) see page 1-11 MAH3000
    P3 Motor Control Tach (to control board input)
    My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
    Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
    I keyed in on this note;
    The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
    Then this note;
    Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
    I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
    The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
    I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
    In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
    With my limited knowledge I will try to help you. Good luck. Rich
    Posted on Jun 20, 2009
    Testimonial: "Awesome help and advice -- thank you to everyone!"
    dblred
    • 68 Answers
    SOURCE: Washing machine stops mid-cycle, water doesn't drain
    Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
    Posted on Sep 12, 2009
    • 4044 Answers
    SOURCE: whirlpool commercial washer stopped running mid
    If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
    Posted on Oct 30, 2009
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Washing machine stops mid cycle - White Goods Help
    www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 8 times pauses and flashes 1 more time. Thank you in advance
    http://www.repairclinic.com/Shop-For-Parts/a11b5d875741/Model-WFW9050XW00-Whirlpool-Washing-Machine-Parts >Go to the website provided and you can check some troubleshooting options. If your issue isn't addressed there click on repair help or Live Chat Now for free assistance. The Google search showed this site and said live help is free. Hope this helps.
    Jan 06, 2015 | Whirlpool Washing Machines
    Whirlpool front load washer will not fill with cold water
    Sounds like your Valve is either inoperative, you have a Clog in the COLD (there is a small screened filter where the hoses connect or your board has went bad..
    Jul 20, 2014 | Whirlpool Washing Machines
    I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 9 times pauses and flashes 1 more time. Thanks in advance
    My Washer stopped while washing and will not spin drain or aggitate.
    It will power on and off I can change the settings but nothing happens.
    Oct 26, 2013 | Washing Machines
    Washer heavy duty cycle issue
    Lid Switch Assembly
    If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Enter your model number to see parts for your washing machine.
    Help me find my model number
    Door Lock Motor and Switch Assembly
    If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Water Inlet Valve
    If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
    Main Control Board
    If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
    Timer
    If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
    May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
    While filling it will flash an F1 code and stop. If I cancel the cycle and press start again it will usually go ahead with that cycle until the nest fill up. What is an F1 code?
    This is a pressure sensor issue on the machine control board .The only sure fix is to replace the machine control board which has been updated numerous times.( whirlpool is very aware of the problems) At one time whirlpool was assisting owners who had this concern .
    Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool washer stops in mid cycle
    check the connection at the main control board top right side just remove the top
    Nov 29, 2008 | Washing Machines
    Washing Machines Logo
    65 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
