Question about eMachines ER1402-05 (884483174195) PC Desktop
Why would my emachines er1402-05 not power up
Everything is plugged in and connected press the power button and it is not coming on
2 Suggested Answers
madhatter639
  • 260 Answers
SOURCE: Not turning on, has power and everything
Do any of the fans spin at all, as though it's attempting to boot up? If not, then double check your power supply to see if it has a switch on it and if it does then make sure it's switched into the ON position. If so, then I would recheck the power connector(s) to the motherboard. If those are well seated then I would start looking at the power switch itself. Those go out from time-to-time. Unfortunately, several eMachine desktops of this model type that I've personally worked on had faulty components on the motherboard; which resulted in having to replace the motherboard. The typical symptoms are that the fans spin and it tries to boot-up, but then nothing else happens: no POST beeps, no video - NOTHING. I have had some of them that just wouldn't show any signs of power\life. I've also had a few of this model type that just stopped working when the power supply went out. The likely cause of that is that the power supply will usually surge when it's dying out; which often results in burning out one or several motherboard components. Once you've reverified that all your cables are connected properly, but you still don't get power, find the 2 wires that connect to your power switch on the case (in your model it's usually the black & white twisted wires. Disconnect the connector, use a small flat-head screwdriver to touch the 2 pins that the connector was attached to. Be careful, there is electricity passing thru these 2 pins when touched together (jumpered), as well as the other pins if you accidentally touch the flat-head to another jumper pin. It should only take a second of jumping the 2 pins for it to start. If it still doesn't start this way, then I suggest replacing the motherboard. You can find good Micro-ATX motherboards on ebay for pretty cheap. If you still want to use your current processor, then make sure you get a motherboard with a CPU socket that's compatible with your CPU. I believe that your CPU is compatible with Socket 775.
Posted on Mar 25, 2010
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Gateway NV5337u Laptop worked yesterday, now only the blue lite comes on when plugged in. No fans or any other sounds.
We might need to talk more, to clarify to solve this promblem. First of all, have you done any update at all to the system? So by what you mean is that when you would go ahead and press the power on button, you get nothing at all... I mean dead, no lights, no fan, completely dead right? But when you have the charger plugged in, the battery light come on only saying it's charging? Is this blue light the battery indicator light, if it is, then that means your battery is fully charged. Try taking out your battery and just using the power adapter and press the power button to see if anything comes on, like fan, lights etc, then try it without the power adapter and only the battery. If you get nothing at all coming at all, I would assume your power button is bad or loose, or the wiring that connects to your powerbutton is loose because i have a gateway Nv series too, and the power button is located where the screen hinges is at, and I'm afraid that when opening and closing, it became loose. This happened to my Emachine, and all I did was took the plastic portion above the keyboard out, and followed the cable ribbon to see if it was loose, or became little disconnect. I kinda just tugged in a little bit and everything worked. I believe it may become loose. Now if the case is that the computer does power on and you get blinking lights, then we are looking at something else.
Jan 31, 2011 | Gateway NV5337u (LXWGD02026) PC Notebook
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
Need schematics for front panel , power sw , pwr led , hdd led et
Try this link to Emachines page. After you put in the make and model and stuff you should be able to view the user manual for your machine. If this isn't what you need you are able to contact support from this page and maybe they can direct you to a more detailed explanation that may help more.
eMachines use specially-made boards for them so there is no manual as such as the boards aren't made to be distributed. Basically they would all use the same sort of connectors and blocks (and cases) to an extent that anybody can plug a connector into the right place and it will work.
The easy way to get round this is to find the power button first - try each two pin connector first, press the button and see if it comes on. If not, move along on the block until you find the right one. Then it's just a case of trial-and-error on the other ones to find reset, power LED and HDD led.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W4065
Mar 15, 2009 | E-Machines eMachines Desktop PC
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
eMachines ER1402-05 (884483174195) PC Desktop Logo
47 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
