Question about Xerox DocuMate 152 Pass-Through Scanner
Error message 0Xc0000005 - Xerox DocuMate 152 Pass-Through Scanner
How to Fix Windows Error Code 0xc0000005 ?
Jacobe,
Need a tad more info? What version of Windows ? What is the system name (HP,DELL etc). When does this error occur? On boot up? or when you login etc.
But here is a start:
Exception Error Code 0xc0000005 Fixed on Windows 7 10 Error Live
Oct 26, 2017 | Computers & Internet
0xc0000005 error
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem Stop Error 0Xc0000005 in Internet Explorer
"Access Violation (0Xc0000005 exception)" is a known problem with Internet Explorer 6.
When you try to open a web page in Internet Explorer 6 that has an opening HTML tag "<SPAN>" without a closing "</SPAN>" tag, this error can appear and render Internet Explorer nonfunctional.
Microsoft provides a hotfix to update versions of Internet Explorer 6 affected by this problem.
Visit the Microsoft Hotfix Request page for this error (see Below).
http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=832823&kbln=en-us
Check the box next to "Internet Explorer 6.0."
Enter your email address in both boxes.
Microsoft will email the hotfix to this address, so be sure it is a valid email that you can access from the computer at which you are experiencing the error.
Type the letters you see in the box.
This confirms you are a human and not an automated bot.
Click "Request Hotfix."
Check your email for a message from Microsoft.
Click the download link in that email.
Save the .EXE download to your computer.
Double-click on the downloaded .EXE file when the download completes.
Follow the onscreen wizard instructions to complete the hotfix installation process.
Aug 09, 2013 | Gateway GT4022 PC Desktop
Please Help...0xc0000005 Application failed to initialize properly!!
Please follow the link below to know more about your problem.
http://www.0xc0000005.net/
Good luck...
Feb 06, 2012 | Computers & Internet
Whenever i click on my c drive it shows hmwfln.exe application error. application failed to initialize properly 0xc0000005. when i click d drive it shows hlgajw.exe application error 0xc0000005 and on e...
0xc0000005 error is one of the errors a PC user can face. This is a critical access violation error that needs a quick response. If this error is not addressed immediately, this problem might destroy the computer system. Because this error relates the computer memory, there is a huge tendency that you are going to experience computer freezes and slow down. The Windows operating system will run slow because of some system defects.
Jul 18, 2011 | Computers & Internet
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
/NOEXECUTE
Oct 30, 2017 | Konami Casino Inc. for Windows
Error message: Physical memory dump
The error code is pretty general and could indicate a few problems. You can try the solutions posted here: http://www.updatexp.com/0xC0000005.html .
Mar 21, 2009 | Acer Extensa 4620 Notebook
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Xerox DocuMate 152 Pass-Through Scanner Logo
24 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
