Question about Pioneer Premier TS-W106C Car Speaker
Pioneer Premier TS-W5102SPL
Where can i get recoil for the pioneers i have 2 x Pioneer Premier TS-W5102SPL and they burnt so i need to replace the coils
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
  • 84 Answers
SOURCE: connection Pioneer TS-W65A
you are probably looking at a dual voice coil subwoofer. This means you have many options of wiring in series/parralel/or bridged parralel. Go to either www.the12volt.com or crutchfield's learning center in order to figure out what your options are. Then you need to find out what ohm your subwoofers and what ohm your amp is stable at.
Posted on Jun 14, 2009
dizzytats
  • 38 Answers
SOURCE: pioneer 4 way ts a6970 what are their wattage
  • 330W MAX.
  • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
  • IMPP composite cone woofer
  • Butyl rubber sound for smoother response
  • Glass-imide voice coil bobbin for higher power handling capabilities
Posted on Oct 10, 2009
  • 396 Answers
SOURCE: pioneer ts-w3001d4 enclosure box specifications
big red
all you need is about 1 and 1/2 foot deep for relly good bass even better if it is vented
Posted on Oct 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
Hot to wire a pioneer premier TS-W3004SPL dual
Check crutch fields website for sub wiring.
Sep 03, 2014 | Car Audio & Video
Manual Pioneer TS-SW1241D
Hi:
I suggest visit this links:
- pioneer-latin.com/en/operating-manuals/mobile-electronics
- manualowl.com/p/Pioneer/TS-SW1241D/Manual/18391
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 01, 2012 | Pioneer Premier® TS-SW1241D Car Subwoofer
Manual Premier TS-SW1241D
Hi there:
Aug 01, 2012 | Car Audio & Video
I have 2 pioneer ts-w253dvc woofers trying to hook up but they have 2 pos and 2 neg on them do i need to hook up all 4 and to what
they are duel voice coil and yes you can hook up both of them you can loop one side to the other and run one wire to the amp make sure you do pos to pos and neg to neg or you will fry your subs
Mar 16, 2012 | Pioneer TS-W253DVC Car Speaker
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Pioneer Premier TS-W106C Car Speaker Logo
77 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
