Question about Dishwashers
Westpoint wqp12 9240
Hi, I'm looking for help with a Westpoint Dishwasher model number: wqp12-9240 first of all I would like to know where I can download its user manual for free, if at all possible? For in the event that I cannot download the manual, I will describe my problem best I can... It seems that the machine gets stuck on its third (the rinsing) cycle where all four lights on the unit light up for a while, then the lights go off and after a while it wakes up again to start draining, but never does so... Any ideas/suggestions are welcome! Thank you
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 898 Answers
SOURCE: My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Posted on Nov 25, 2006
SOURCE: Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Posted on Sep 25, 2007
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
My westpoint machine model WMC-5260 SERIES DOES NOT WORK WELL. IT IS AS IF THE TEHRMOSTAT HAS FAULT. where can i find a maintainance engr in nigeria?
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for 'westpoint washer service' for instance or 'westpoint washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 04, 2011 | Washing Machines
I have got a westpoint washing machine XQG50-604 the water switch is faulty but the machine is working it doenst pour water on the machine at all.rose e-mail:rntuli@uj.ac.za
Hi
I have a Westpoint front loader washing machine, model number XQG50-604. The power button got stuck, opened machine up and find the power switch burnt out. Where is Johannesburg in South Africa can I get a new switch please? Also can you advise how to remove old switch and to replace the new switch.
Regards
Juanita
Feb 15, 2011 | Washing Machines
I want the manual of WESTPOINT WMB-50T
I have big problem my washig machine is a top loading Westpoint brand, model : wtw-700 its drain well but can't spin at all please help .
Sep 30, 2010 | Washing Machines
We have a westpoint wkw1225tl and the program
once machine fills with water a pressure switch activates to say stop filling now wash/ the motor should then start and heaters operate with the timer decreasing dont know your model too well but hope this helps you....
Nov 05, 2009 | Washing Machines
A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
Jan 12, 2009 | Westpoint TV-201 Microwave Oven
How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Oct 19, 2008 | Heating & Cooling
Westoint Dishwasher
Hi jannewbery,
I'm Harvey the Master Plumber.
Your problem is: You have looked in the manual under troubleshooting tips, but didn't find anything on the problem. The dishwasher goes into cycle,but during the wash cycle it stops,makes alarm and the wash and rinse ligts come on. And now you can't even find the product on this site.Westpoint Dishwasher WQP12-9240.
Thankyou Your dishwasher is stopping at stage 2 of the programme after beeping once. Quite often the detergent flap doesn't open. Am at your wits end and threatening to leave home!!!! The machine is less than a year old. PLEASE HELP!!!! Thank you.
Don't leave just yet. It sounds like a control problem. The d/w should still be under warranty if it is less than one year old. Use it before it runs out. I don't recomend this type of repair for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
I put the mahcine on as normal but it does not go past the first cycle of the red flashing light?
Sep 08, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
