Samsung SGH-d807 Cellular Phone Logo
Posted on Aug 11, 2007
Wont turn on
My samsung d807 phone lights up when the power button is pushed but it does nothing else. No welcome screen, no cingular start up. The screen and keys light up and that is it. I was wondering if it could be the OS on the phone or an LCD problem. The screen and keys are very bright. Does anyone know if there is a hard reset on the phone.
  • martyfast Jan 07, 2008
    turn fon on, just the first screen appears(name, model) and stays there,, does not continue from there,,,wont turn off then,, have to remove battery to turn off,,, installed new board, worked for a couple hours, then same thing,, new board is under warranty, going back to repairman in the morning,,,
    Can anyone help,,any ideas
  • Dennielle Jan 07, 2008
    I was sending a text and it just froze so I took out the battery and it wouldn't work. this has happened before but then it went back to normal... what can I do?
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Aug 11, 2007
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
5436
Points
53
U r phone is shortby water at first cleen it by ipa cleener dont use petrol& water than u have to flash it flash mcu and ppm if problem will still ther than give heat treetment to flash ic and cpu cleen all pins(cunector) chack battery voltage it should be min 3.7volt than put it in to phone properly and switch it on it wii on 100%
1helpful
I dropped my sgh-d807 in water,the screens blank and wont turn on
u broke your phone becus i did the same thing and had to buy a new phone sorrythat happened
Need master password for my samsung sgh-c425
I found this off another site. I have tested this withy my D807 and it works.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin)
3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone.
My Samsung SGH-d807 is locked, and i have tried to unlock it 5 times after which it says a message that permanently locked to cingular network.
1a. NOTE: Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
4. White screen will appear with an exit option. Press the right softkey. (you may have to push the down key to get a menu)
this may be what you allready tried, but it worked for me, good luck
2answers
Button problems
same thing with mine! the buttons wouldnt work at all except the number button so i decided to remove the battery and restart it but now i can turn it on cause the turn on button wont work!
2helpful
4answers
SGH-D807
D807 Unlock Samsung SGH-D807 SOLUTION
for those that need this code. It's a lot cheaper than 29.00 from some of these websites....
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone only you will need a data cable..
2answers
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Unlock code
    NOTE (Modification here by my experience): Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
  2. Put a SIM card that is from a network other than the one your phone is locked to.
  3. When Incorrect SIM error comes up, input *#9998*3323#.
    You now have an UNLOCKED Samsung D807
  11. With the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card.
Samsung D807 shorting out? - sound and screen problems
you must reinstall SW. cant you help me? I can't found an LCD screen for my D807, are ther an compatible one (ex 800, 820, 900 ...?). thank you
Turning on my phone
call cingular and they will give u the code
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
