Codes help find problem where do i start
05 ford f/150 5.4 3v 245,000 miles it runs great drove it night before no problem next day it idle rough drove on highway it start to miss shake sputter it would stall but start right back up i change all spark plugs fuel filter it runs little better but once put in drive it wants to stall it idles so put a code reader on it at idle no codes drove it the n codes p0012 p0174,p0300,p0302,p0303,p0304,p2195 what do i do
  • 7,627 Answers
Wrong Category
Posted on May 08, 2013
2 Suggested Answers
  • 4961 Answers
SOURCE: 2004 impala 3.8 misfiring stalling out. no check engine light comes on
You should post this question in the cars section.
Posted on Jul 16, 2012
Car wont idle
There re few possibilities that can cause no idle issues.To troubleshoot the issue help links are provided below.Click the link below:---
Idle Problem? http://whatisbyme.blogspot.in/2012/05/2001toyota-corolla-idle-problem.html
Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
Cooling fan Shuts OFF and Idle Drops? http://howtobyme.blogspot.in/2012/05/toyota-celica-cooling-fan-shuts-off-and.html
Rough Idle and Vibration? http://whatisbyme.blogspot.in/2012/05/2006-ford-f150-rough-idle-and-vibration.html
Steering Wheel Vibrates at Idle? http://whatisbyme.blogspot.in/2012/05/1993-toyota-corolla-steering-wheel.html
Runs Fine But Idle Is Low? http://whatisbyme.blogspot.in/2012/05/2004-toyota-highlander-runs-fine-but.html
Vehicle Will not hold Idle? http://whatisbyme.blogspot.in/2012/05/2003-lexus-es300-vehicle-will-not-hold.html
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
This will help.
Thanks.
Jul 17, 2012 | Cars & Trucks
How to diagnose rough idle and hesitation on gmc sonoma 2.5 4 tech?
Hello I have a 1995 Sonoma 4.3 with 150.000 on her and she ran great tell last week went to pick up a lite trailer and dove it home no problem drove it all day after that. The parked it running fine and next morning it won't hold a idle but clears up at 3000 RPM runs fine drop in gear and it won't stay running??? Cleaned TBI and there was a new fuel pump and filter put on it less them 7.000 miles ago. Found vacuum leak on the booster to manifold fix that still runs like it is misfiring??? Any help would be great thanks no check engine light on.
Feb 17, 2012 | GMC Jimmy Cars & Trucks
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
History: 2 days ago the battery light came on. Car ran fine that evening. The next morning. The tach stopped working. a minute later the speedometer stopped working. Then, another minute later, the car...
Replacing the fuse the first time was the right move, becuase it could have been a fluke that it blew. Replacing it again and again was not! You should have found out EVERYTHING that the #2 fuse controlled and verified that the components weren't pulling excessive amperage (shorted condition). By replacing the fuse over and over, you might have made the problem worse by subjecting good components to something that was shorted.
BTW next time pick the oldest guy at autozone to help you, if the counter help knew their stuff they would have told you the same thing I just did!
Sep 04, 2011 | 2000 Ford Contour
The 12 volt battery(LUCAS 065/3) on my FORD FIESTA 1100cc is 4 years old, in that time i have only driven 1,600 miles as my journeys are usually very local. I make sure i use the car twice a week to keep...
Running so few miles has accelerated the aging of the battery - the battery never had a chance to fully recharge in such small trips -  so now you have to replace it a year sooner than usual.
Just replace it.
Aug 28, 2010 | Ford Escort Cars & Trucks
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
1997 mpv mini van runs great. While traveling i drove from SC to Atl GA....parked and went into motel for evening...the next morning i had very difficult time getting it re started....Like it was not...
I think you should check your battery and alternator.If they both check good you may have a battery draw,something draining the battery over night.Check your doors make sure they are closing like they should.
Jul 28, 2009 | 1997 Mazda MPV
2001 VW JETTA SPUTTERING AND BACK FIREING WONT GO OVER 10MPH
First check all wires for any thing loose.
The muffler blowing up leads me to think the engine is so far out of time the PCM cant correct it.
REally you need to get it to a good mechanic.
Jun 26, 2009 | 2001 Volkswagen Jetta TDI
Stalls / Dies / dead
this engine fuel pump prassurae low. it fuel pump celan. Your problem sovel
Jul 13, 2008 | 2003 Ford E150
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
