Bosch ahr 1000 pressure washer
Can't get into this machine to check motor brushes. Any help gratefully received.
gittos73
  • 244 Answers
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Posted on Feb 25, 2008
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Posted on Apr 26, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Posted on Feb 11, 2009
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
Why is my machine showing F _08 cant take it off
What brand of washer is it? For Hotpoint and Indesit washers, the F08 error can mean a problem with the heater relay. If the error shows up at the beginning of the wash cycle, you should look at this relay and the heater. Also check the pressure switch and wiring. If the error occurs near the spin and drain cycle, it can mean a problem with the motor/motor brushes. (If you hear a grating sound, then the motor is the likely suspect.) Sometimes, moving the washer out will identify this problem. If the brushes were sparking, there may be carbon black deposits underneath the washer. In that case, replace the brushes.
If you add a comment with the model number, I may be able to provide additional assistance with finding the appropriate parts. I hope this helps. If your washer is under warranty, you should contact the manufacturer.
May 06, 2015 | Washing Machines
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Bosch Nexxt 100 Series WFMC1001UC/05 Front Load Washer that the brushes in the motor are wearing out. Were can I buy a set of brushes at? Any information would be helpful.
Part number is 154740 around 36 dollars from http://automaticappliance.com/ How to video from YouTube http://www.youtube.com/watch?v=N_r8d93xPYw&feature=youtube_gdata_player Different model washer but same motor. Look up videos for how to replace the belt if you have trouble. Symptoms of worn brushes include weak or no spinning.
Aug 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch classixx 1000 washing machine is not spinning at the end of the wash cycle, and when set to spin it does not spin, what can i do?
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl vote me 'very helpful' for the free help, thnks!
Apr 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby pin. i removed the bobby pin. when machine is on spin cycle only the pump opperates. does not spin at all....
If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Dec 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
Changing the brushes when the motor is off
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
