Question about HP Officejet 5610 All-In-One InkJet Printer
Ip address how to know the ip address of the officejet 5610 all in one printer
    Problem Solver:
  • 8 Answers
If your home or office printer is part of a network, meaning it is connected to a networked computer or router, then it will have a TCP/IP address identifying it on the network. This address can be used to share the printer with new users on the network, or to get ink and paper levels on your computer. This address can be found whether using a simple printer, or a printer/scanner combo machine such as the HP Officejet 5610, which will be used as an example here. M/F Click your PC's "Start" button and choose "Control Panel."
M/F Choose "Printers and Faxes." Left-click "HP Officejet 5610" and choose "Properties."
M/F Click "Ports" then drag the divider between the first and second columns to the right to display further information about your printer, including the TCP/IP address.
M/F Open the "Applications" menu and choose "System Preferences."
M/F Click "Printers."
M/F Choose "HP Officejet 5610" and click "Options and Supplies." All network information for the printer will be displayed.
Posted on May 10, 2013
5 Suggested Answers
  • 628 Answers
SOURCE: dismantle and remove battery officejet 5610
It would be extremely difficult to disassemble the printer, and the battery is usually not replaceable. Why did you want to replace it anyway? It should last the life of the printer.
Posted on Dec 01, 2008
tumi001
  • 102 Answers
SOURCE: I wanted to know if there is a free download of hp
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab57
Posted on Jul 17, 2009
tumi001
  • 102 Answers
SOURCE: Please help me
hi,
ab95
bandana_gyrl
  • 181 Answers
SOURCE: Howdo I find my HP Officejet 5610 all-in-one
You won't be able to get an IP address for the printer. The unit is not network capable - it's USB only. An IP address identifies the printer on the network.
Posted on Apr 22, 2010
Computer has a different ip address than my hp 8600 printer and says it is offline when it isn't
This should work (assuming that you are using Windows Vista or newer):
Remove the printer from Windows (in Control Panel, Printers And Devices right-click and choose "Remove)"
Then choose Add Printer and follow the wizard and it should find your wireless printer automatically.
Please let me know if this doesn't work.
Jul 03, 2014 | HP Officejet Pro 8600
Wired connection ps3 cant obtain ip address
If your home or office printer is part of a network, meaning it is connected to a networked computer or router, then it will have a TCP/IP address identifying it on the network. This address can be used to share the printer with new users on the network, or to get ink and paper levels on your computer. This address can be found whether using a simple printer, or a printer/scanner combo machine such as the HP Officejet 5610, which will be used as an example here. * Click your PC's "Start" button and choose "Control Panel."
* Choose "Printers and Faxes." Left-click "HP Officejet 5610" and choose "Properties."
* Click "Ports" then drag the divider between the first and second columns to the right to display further information about your printer, including the TCP/IP address.
* Open the "Applications" menu and choose "System Preferences."
* Click "Printers."
* Choose "HP Officejet 5610" and click "Options and Supplies." All network information for the printer will be displayed.
Mar 15, 2013 | Sony Playstation 3 (PS3) Console
Hp officejet 7210. When router resets, I loose my printer connection.
IS this printer wired LAN to your router? If so, look in the settings to your printer and check the IP address.
Now in the settings menu, it should have an option for you to set DLNA or manual. Set to manual. Enter the same IP address the machine originally had. If you could not find what ip address your printer had, in windows startmenu find run or command prompt and type ipconfig all.
Find the ip address for your computer. Add 10 to it. For example, if it is 192.168.0.2 than give your printer 192.168.0.12 If it asks for a subnet mask use 255.255.255.0
I believe the problem you are having is that every time your router resets it gives your printer a different ip address (dynamic IP), so your printer driver software can no longer find it. You need to use a static ip address (manually giving the printer an ip address) so it never changes and the driver can always find it.
Sep 24, 2010 | HP 7210 OfficeJet All-In-One Printer
Wireless printer not printing
Check if you are able to open the printer web page (EWS) on the computer.
you can check it by obtaining the printer ip address from setup-- network setup---print network configuration page. (Inn case of HPprinter)
suppose the ip is 192.168.1.100 , then open a new window of internet explorer and open the address as http:\\192.168.1.100 and see, if it is displaying the printer information
If yes, then open the printers window from control panel on computer.
Right click on your printer icon which has a check mark and select properties.
click on ports tab and click on addport button , selct the port as standard tcp\ip port and click on new port .
enter the ip address and finish this wizard, you will be back on ports tab .
now, right click on the printer icon and select use printer online.
Apr 03, 2010 | HP Officejet 5610 All-In-One InkJet...
Howdo I find my HP Officejet 5610 all-in-one printer's IP address? Please make it simple!
Feb 22, 2010 | HP Officejet 5610 All-In-One InkJet...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How to fax with the hp 5610 officejet printer
hi,
ab86
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
HP Officejet 5610 All-In-One InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
