Mitsun 5.1 home mit 2050 theater on power
No power in sub woofer
SirHanz
  • 145 Answers
SOURCE: jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Posted on Jan 27, 2008
SOURCE: RCA Home Theater Receiver won't work
I had the same problem but it happened 2 years ago. i went out and bought a new receiver for $200. The RCA receiver has flaws and isn't worth fixing
Posted on Feb 16, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
MrScary66613
  • 1990 Answers
SOURCE: OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Posted on Jan 02, 2009
  • 336 Answers
SOURCE: inputs cable broke off into my input packs
You might be able to fix it yourself. Input jacks vary some you can use a pin or straighted paper clip to push the broken cable out. Remove the screws on the back (you my need to disconnect the speaker). If the jack is accessible (some are sealed ) using the clip or pin try to push it out from the back side of the jack.
If that doesn't work you are looking at about $50 to $70 replace the jack.
Posted on Mar 08, 2009
Sub woofer not turning on
Is it receiving power? If not that is your answer - could be a blown fuse, bad wire, bad connection, etc.
If power is there and it still does not work then the problem coud be with a bad sub woofer on/off switch, internal fuse, or worse, blown amp from over driving.
Feb 25, 2016 | Boston Acoustics MCS 90 Horizon Series...
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
Mitsun mit-1980u 5.1 display not working
I'm sorry. Could you please try to restate your problem. I can't understand you.
Feb 03, 2014 | Audio Players & Recorders
The left channel on my Nakamichi SoundSpace 8 has suddenly started
  • Complete home theater system with top-loading DVD/CD player, surround sound processor with AM/FM tuner, and center channel amplifier
  • Includes 5 satellite speakers (2-way, 3-drivers each) and dual active subwoofers with 6.3-inch woofers in bandpass enclosures
  • Supports DVD, CD, CD-R/RW, and MP3-CD formats; processor integrates DTS, Dolby Digital, Pro Logic II, and synthetic surround effects
  • Built-in sub woofer amplifiers separately power left- and right-channel satellites to minimize interference and crosstalk
  • Satellites measure 3.1 x 7.2 x 3.9 inches (W x H x D) each; subs measure 8.9 x 20 x 9.6 inches; 2-year warranty
Jul 22, 2012 | Nakamichi SoundSpace 8 System
I'm in dumaguete city, where can i find a sub-woofer speaker for my Sony MHC-GNZ8D mini component?
What kind of sub woofer do you need? a powered one? or simple a sub woofer?
Jun 03, 2010 | Audio Players & Recorders
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
 Grubhead
Grubhead
