Question about Canon PowerShot A75 Digital Camera
ImageMate USB I took pictures with my camera, and decided to put them on the computer, rearange them, then put them back in my camera in the groups I wanted. However, I put them in my computer, rearanged them, and they ended up not showing up when I put the memory card in my camera! They show up on the computer though with my memory card. How do I put them back in my camera?
  • 137 Answers
Copy and past. If it is corrupt, scan computer and card for virus.Espesialy worm virus.
Posted on Dec 24, 2007
SOURCE:
I have a Sony Alpha a300, i took around 400 pictures, and 2 groups of pictures got erased, around 150 of them. The rest are still there. What can I do?
you can use recovery tools. remove memory card and put into memory card reader. connected to computer. download recovery tools like get data back or other recovery tools,try this link download it and try to scan your memory. other recovery tools has a trial period get software that has free trial
Aug 23, 2011 | Sony Alpha DSLR-A300 Digital Camera
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Apr 08, 2010 | HP Photosmart M547 Digital Camera
My olympus fe-45 won't download pictures through the usb cord. It takes pictures fine, but when I plug it into the computer, the camera screen says 'one moment' and it stays like that, and the computer...
This is not a full solution, but you might try another USB cord or a new USB 'hub' or simply another version of photo transfer. I have had good results with SanDisk's 5 in 1 ImageMate card reader and accompanying software. Used Targus but it stopped working. Went back to SanDisk. USB is wonderful but there are so many access points for things to go wrong, including the jacks in your computer. Have just fought this through with a set of headphones which had worked great for over a year and then stopped. Fixed with a new 'mini-hub' and plug-in audio controller which replaces my sound card. Now can use USB connections on front of CPU and webcam finally works as well as headphones (much better music) and photo transfer. $25 well spent. Can return new headphones I ordered.
Oct 24, 2009 | Olympus FE-210 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
I just got back from my first cruise and took so many pictures. I don't have a USB so I went to go place the memory card into my computer but it won't read the card. So when I put the memory card back into...
i know its not ideal but why dont you borrow a friends camera and usb lead, put your card into their camera and upload them onto your computer via their camera, at least then you can save your special pictures and rectify the problem later
Jan 18, 2009 | Cameras
How do i put my pictures on the computer
  1. use the proper cord to plug camera into a usb connection on the computer-the computer will guide you from there. You will have to name the pictures and decide where to store your pictures in your computer.
Aug 31, 2008 | Fuji Cameras
Memory card
use a sd memory card reader-no software-plug and play-make sure you don't have 2 folders in camera storing pics in different places-check in menus for folder numbers
May 23, 2008 | Canon PowerShot A620 Digital Camera
Help please
coach camara means rearange pics you should probly read the users manul
Mar 31, 2008 | SVP DV12TB Digital Camera
Gone?
buy a memorycard reader and stick it in the computer. not by usb cable on the camera
then
You might use a program like ontrack easy recovery.
choose data recovery then formatrecovery.
goodluck
Dec 07, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
