Question about Garden
Repair karcher k480m
I thought i had most tools does anybody know what tool( long) to get at fixing screws on a karcher k480m please
SOURCE: what to do with watch repair kit
Unless the watch back has notches on it, you want to look around the edge of the watch and find a little lip. When you find the lipp, use one of the knives and pry open the back. Take one of the tweezers and pull out the battery, you could also use one of those handy-dandy screwdrivers to pry out the battery. Put the new battery in laying exactly like the old one , then proceed to close the back, making sure that the little notch (on the INSIDE lip of the back case) lines up with the stem and crown (the part used for setting the watch) so not to break it. The back openers and the knives are just differant ways to opn the back of the watch. Sometimes watches have screws on the back that need to be taken off in order to open the back case. The case vise is to minumize the wear and tear on your hands. The tweezers are for taking out the battery. If you have anymore questions PLEASE feel free to contact me I will be glad to assist you further! Good Luck!!!
Posted on Aug 12, 2008
greg_margo
  • 1959 Answers
SOURCE: TIMING BELT REPLACEMENT FOR 2000 DAEWOO LANOS
I found a few, most running over $100, this link has the equivalent tool costing much less. I 'll leave both links and you can choose. Best of luck on your repair.
http://www.denlorstools.com/home/dt1/page_13788_520/sealey_vs090_daewoo_water_pumptiming_belt_tool.html
http://www.etoolcart.com/browseproducts/Daewoo-Timing-Belt-Adajuster-J-42492-A.html
Posted on May 09, 2009
SOURCE: Removing the headlight bezel. cannot remove last
You need a small midget with very small hands to reach that last screw
Posted on Nov 24, 2009
SOURCE: how do i remove the chuck from dewalt dc925
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Posted on Feb 02, 2010
SOURCE: Hello I'm fixing my poulan pro ppb200 gas
My service center told me that they are allowed only 2 of these adjuster per year. It has to do with the air quality issue. They don't want back-yard fixer-uppers to pollute the place up. True store - I could not believe it.
The BLUE wire-splice connector, the one that you crimp after you put a wire in each end, is supposed to fit snug around those screws and allow you to adjust them. However I could not get it to work.
If you take a hack saw and cut the lip from around the adjuster screws and then cut a slot in the adjuster screws themselves, you will be able to set those screws with a flat-head screwdriver.
The whole operation takes about 9 pushes of the hacksaw. The lip is aluminum and the set screws are a very soft steel.
Good luck
John
Posted on May 06, 2010
Disassemble ena 4
As far as I know the Jura machines have a special oval shape screw head on their panels...and Jura charge something outrageous like 150euro if you want to buy the tool for opening these! Mite be worth trying to open it some other way like by gluing a tool or something into the head and let it dry, then open it.... then maybe replace the oval head screw with a different screw type when reassembling. Not an easy method of getting past the problem but id sooner do it than pay for the tool!!
Hope this helps
Dec 04, 2012 | Jura Capresso ENA 4 (13421)
Karcher KB4040 pulsing when trigger closed and has lost about 50% of its power
Just google " stripping down Karcher KB4040" A YOU TUBE CLIP will show you hiw to fix it and what tools you need
Jun 05, 2012 | Garden
Anybody got a redg key for a good pc repair tool
I would recommend to use intel partner pc repair tool like Reginout to optimize PC. It has several feature to fix windows errors.
Apr 23, 2012 | Computers & Internet
Hilti says they cannot fix my t14. does anybody work on t14?
If Hilti tells you that they can't repair it I don't know of any source. You might check your local phone book under tools/repair for a repair shop but not too many people work on Hilti products. Have you tried calling their technical service/customer service also, 1-800-879-8000. That would be the final disposition I would think. Good luck
Jan 25, 2012 | Drills
How do you replace the pressure loading valves
if it is a karcher machine you will need to remove the pump, and the valves need to be removed with a set of valve pullers, karcher sell the special tool needed for this, you cant remove the inset types any other way but with the tool,
any questions just ask away
Feb 24, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Water spewing from the front, don't have tool to open housing
Dear outfielde901,
Regarding the sprays out of the front, this could be to many reasons. Most common is an inlet elbow is broken inside. Even the head could be faulty. But the most important is to open the cover. Yes you need a Torx 15. A torx 15 is a very simple screw driver, that it is not flat or philips...but it has a six ended end. The screws have six ended holes. You can very easy buy a set of screw drivers and in the set you see that you have a T15. Now it is better that the T15 has a hole at the end. This is called a security screw driver. In the screw there is a little pin in the middle...so a normal T15 will not fit. If you are lucky, all screws might be normal with out the little pin. So a normal T15 will do. I bought various sets of these TORX from ebay for a very little price. If you buy a set consisting from T10 to T20 and even T30 andT50 it will be better. You can also buy these screw drivers from a normal tool shop or iron monger. My edvice first buy a T15 to open the cover.....then see what tools you need more. This because some washers they have inside Allen Screws. So then you buy a set of Allen Keys.
The other problem for you might be from where you buy spares. This I cannot help you, because I am not from your country. So remember ..a T15 is a simple screw driver. With a cheap set of Torx and a set of Allen Keys you can fix your problem yourself. Very Simple!!!!
Regards,
Fulltech.
May 22, 2009 | Karcher Garden
How do i use the watch band link tool i just got with no instruct
Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
Do not forget to rate, please.
Feb 11, 2009 | Rolex Datejust SS
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
