Question about Dryers
Whirlpool wed9400su0 F28 error code, dryer won't start
  • 85 Answers
SOURCE: whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Posted on Dec 14, 2008
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
  • 63 Answers
SOURCE: whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Posted on Oct 28, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer, error code f28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
Possible thermal fuse on blower housing, that's usually the problem if the timer is still ticking, it can be tested for contiuinty with a meter
Jan 23, 2014 | Whirlpool Dryers
F28 error code
I have a LG washer and dryer and mine get a PF code for power failure. I don't know if that's helpful or not. Contact the manufacturer for information on what the different codes mean. You can also look at the booklets that came with your machine. A lot of times, manufacturers will have the user manual online at their site.
Dec 10, 2013 | Kenmore Elite HE5t Washer
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 | Dryers
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
Whirlpool duet wfw9200sq02 f28 error code
What the F28 error code means is "serial communaction error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F28 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it advise, ya call for service so the operation of both control boards can be checked to see which on has failed.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
70 people viewed this question
Top Dryers Experts
