Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
New bulb My bulb went out I moved into a new house I installed the bulb about 6 months after it first went out. Now the screen is acting funny its kinda blue greenish with wavy lines sort of the bottom is a long box the top is a long box and the whole middle is a larger box. Not sure. Please help.
    Genius:
  • 1,153 Answers
If you have no video or OSD then:Suspect the FMT PCB part # 930B924002.
Posted on Oct 06, 2007
SOURCE:
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
Tip
Replacing HeadLight Bulbs on 2006 Tribeca (Left side)
Step 1: Loosen up battery housing and move battery to the side.<br /> 2: Unscrew plastic cap.<br /> 3: Pull off electrical connectors.<br /> 4: Un hook retaining clamp (good luck with this one)<br /> 5: Pull bulb out<br /> 6: Put new bulb in without touching bulb (again good luck with that)<br /> 7: Re connect retaining clip<br /> 8: Re connect wiring (guess which one goes where)<br /> 9: screw on cap<br /> 10: Tighten battery housing <br /> 11: Be prepared to have to do it all again if the bulb is not secure or blows in 5,000 miles! <br /> <br />
on Nov 07, 2010 | Subaru Tribeca Cars & Trucks
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
Mazda 6 sport sedan break lights not working after hid light conversion
Instructions Open the rear deck lid on the Mazda 6.Carefully remove the plastic finishing cover from the license plate light housing, using a small flat-head screwdriver to release the locking tabs. Pull the cover downward and off of the deck lid, exposing the license plate bulb.
Remove the old light bulb from the license plate bulb socket by hand. Wrap your new one in a paper towel and do not touch the bulb with your bare fingers. Insert the new bulb into the light socket. Install the finishing cover onto the light housing and push it upward until it clicks and locks into place.
Repeat Steps 2 and 3 to complete the LED light conversion on the opposite side of the deck lid. Test the new bulbs by turning on the headlights on the Mazda 6.
Mercedes Parts.
May 25, 2012 | 2004 Mazda 6
Just bought this house 4 months ago. Sharp Vision XV-Z9OU Projector came with the house (installed 2004), last night bulb went out.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 19, 2012 | Sharp Projector Lamp for XV-Z90U
I have a Eee pc series that has Linux os I belive for the system and I went to turn it on and it is acting funny it looks like it wants to load but some weird stuff happens on my screen I don't have my...
Hi, Linux is a free distributable operating system. You can download and burn it on disk like Ubuntu. You can go ahead and install the OS on your computer once again. The installation of Linux is very easy and you can go through the wizard and complete it.
Cheers!
Mar 13, 2010 | ASUS Eee PC 2G Surf Notebook
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
