Question about Dishwashers
TEKA dishwasher dw6 59 fi 2 last lights blinking
Hi! I'm having the problem illustrated in the picture bellow. http://i90.photobucket.com/albums/k266/typhoon_2099/dishwasher.jpg I have the last 2 lights blinking problem... can you please help me? tilted the machine to drain the water that was blocking the system of aqua-stop. hung up and tried to reconnect tried to reset (but could not) 5x clicking the button programming when connected machine.
BIKER T
  • 909 Answers
SOURCE: Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Posted on Oct 08, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Whirlpool ADP 9520
press the start button (which is flashing) for a few seconds and it should start again?
Posted on Aug 20, 2008
  • 192 Answers
SOURCE: Help me please - Gateway FPD2185W
Ok, I have some news on this that I know you will not like, but the whole point of this site is to try and help you fix the problem, or at least, try and point you in the right direction.
The news:
I have done some extensive searching on this problem over the last month, as I have also had a friend with a similar problem that you are describing. There is a manufacturer's fault on the main power board, this has been recognised by Gateway, but as it happens inconsistantly (it may happen after a few months or a few years), they are not prepared to recall the product.
Obviously this doesn't help us as consumers that buy their products. The blue screen that you describe happens with alot of visual hardware inc. graphics cards that affects the whole market, and has now become affectionately known as The Blue Screen Of Death (BSOD).
If you are one of the lucky one's, and it is still under the manufacturer's warranty, get it sent back asap, and ask for a replacement to a similar model. If not, the only thing you can do is get it repaired or get a new/2nd-hand one.
Like I said, I'm sorry this isn't the news you wanted, but I didn't think it was fair for you to hang on.
Regards
Tim
Posted on Dec 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Ekaitz here! Snaps of the Sony board!!
Thanks, will let you know shortly.
Posted on Dec 30, 2008
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Hi my teka dishwasher dw7 56 fi makes a noise when first switched on .
what is it supposed to do . be so quiet you can not hear it working .
Dec 07, 2015 | Dishwashers
Teka dw655 f1
Is electric,gas or steam heated? :)
I'm joking..for a small DW should be electrical heated.
Can be. 1..no power provided to heating element
.2..heating element broken--easy to check with one tester
3.connections for that heating element can be rusted or broken
Good luck
Jun 30, 2013 | Dishwashers
The detergent box did not open during the last wash and at the end of it the green "clean" light is constantly blinking now, and i can't get the dishwasher to start any programs.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 14, 2011 | Dishwashers
Lights blink but nothing works
Hi, disconnect the power supply for few minutes, say 5 minutes and then turn it ON. Check, if that helps. If not kindly revert with more details :-
1. Which light is flashing?
2. Is there any message like ' CL ' or anything you could see?
3. How old the machine is?
4. Is there any sequence in blinks like 7 blinks then pause and then 7 blinks?
Let me know,so that i could provide you with more accurate diagnosis.
Jun 21, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Need an english manual for teka dishwasher dw6 59 f1 please
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
How to reset a dishwasher teka lp700
i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
Apr 19, 2010 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
